Results 1 to 6 of 6
Thread: Autron CC
    Autron CC
    Hi all , noticed after my motor was repaired that my CC doesnt work anymore.
    Light goes on but it wont set any speed. .
    If someone could tell me where the Autron cruise control is I might be able to retrace it.
    As far as I know the engine remained in the Patrol to do the head work.
    TIA TD
    Bumped................
    The master farter
    mudski's Avatar
    465 Post(s)
    Got no idea John, being an aftermarket thing I would guess up under the dash somewhere. You'd have to find it and trace the power wire to it and see if its fused and if so, is it blown. First thing I'd check for.
    Patrol Guru paulyg's Avatar
    Ballarat
    I had a similar problem with mine, turned out to be the battery in the controller on the steering wheel. it takes a button type battery
    2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
  6. #5
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    It will be wired into your brake lights - probably not far from the brake light switch. Should be able to identify that and trace the wiring back to the unit.
    If it picks up the vehicle speed via an inductive sensor and magnet on a shaft somewhere then that is a likely culprit as it might have been interfered with during engine works.
  7. The Following User Says Thank You to Brissieboy For This Useful Post:
    threedogs (8th July 2020)
  8. #6
    Quote Originally Posted by Brissieboy View Post
    AH that might be right as recently I changed the brake light switch.
    Will check it out very soon Thanks
