Results 11 to 20 of 25
Thread: What Car?
    Not a V6. They are a nightmare to even change a timing belt or stretched timing chain. A straight six or four is the go. We have an old Ford Courier as a paddock bomb and it was used by a lawn mower service for many years before we got it.
    May 2016
    lower west victoria
    30 Post(s)
    Oh, OK, I'm more of a Ford guy anyway. Looking at a neat looking AU ute, ATM, I got a soft spot for AUs, had 2 of 'em. Biggest problem is it's in Bayswater.
  4. #13
    I test drove a 2002-3 Ford wagon from Mark Smith (Bolwarra) a couple of weeks ago. It was only a couple of grand and was a bit shabby, but it nearly snapped my neck when I floored it. By hell, those big sixes have some grunt.
    He will obtain a vehicle to your specs too.
  5. #14
    May 2016
    lower west victoria
    30 Post(s)
    Hey, good to know. Is he still in Portland? I saw he's not near that Shell servo anymore.
  6. #15
    462 Post(s)
    It will have been flogged if its from Bayswater. Lol. Yobbo central.
    10G (29th June 2020)
  8. #16
    May 2016
    lower west victoria
    30 Post(s)
    Hahaha, yeah there's that as well. I was more thinking that it's at best a 5 hour drive away.
  9. #17
    He works from home, so just google Mark Smith Motor Traders Portland and give him a bell.
  10. #18
    May 2016
    lower west victoria
    30 Post(s)
    Job's done. Got myself a 2001 AU ute with a tub. 280,000kms which is about 14,000 per year which is pretty good. On petrol, not gas.
    Needs a bit of cosmetic work done. Headlining is shot, driver seat is stuffed, mechanically it's not too bad I think, diff moans, but they all do. Hope to get at least another 200,000 out of her.
  11. The Following 2 Users Say Thank You to 10G For This Useful Post:
    mudnut (4th July 2020), Rossco (3rd July 2020)
  12. #19
    @MB backfiring is from a couple of easy checks,
    First is air leaks on the intake side, a decent backfire could blow the air box out.
    The second is tooo lean, find the main gas in hose and unscrew 1/4 turn or find the
    screw with the spring on the condenser and and turn clockwise one flat on the hex
  13. #20
    On our EB, I took the whole head liner out and bought a couple of tubes of grey silicone. After scraping that shitty foam underlay off, I coated the board with silicone, laid the headliner back over it and used scraper to smooth it all out. If you bother looking up, you can see where the silicone oozed through the cloth. Meh, it passed road worthy and will never peel off and fall down again.
    It will also make a great base to stick the velour headlining I intend to put in.
