Results 1 to 2 of 2
Thread: Leaky Deisel pump...O ring?
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    Poor girl hasn't seen the tracks since March...been giving her a run every week but last week I noticed some clean areas on the fromt pumpkin...
    Got down and had a look around...looks like a leak from the side of the fuel pump...
    The lil inspection plate on the side is letting the fuel out...
    Seems to be a common thing around the traps...anyone done the repair? As far as my knowledge bends I need to remove the small plate and replace an O-ring behind it...
    Any other info would be a plus...
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
    Expert Deano2506's Avatar
    Apr 2017
    Hobart,tasmania
    G'day mate.yes,it is just an o ring under that plate.
    That might not be the leak though.
    Top cover is the usual spot,drips down and makes it look like it's the o ring.give it a good degrease and check where the leak is coming from first.
    99% of the time once 1 seal goes and you replace it,another one will leak soon after.
    Good luck with it mate
