Results 1 to 6 of 6
Thread: Short drill bit set
    Legendary
    194 Post(s)
    Short drill bit set
    I bought a right angle drill, but to get the most use out of it, I am looking for a set of short drill bits say from 2mm to 13mm in diameter. The drill needs the unfluted shank in the chuck, but I can't find a set anywhere. Chime in if you know where I can source them -i have tried Total Tools and ebay - nothing.
    Legendary
    194 Post(s)
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    mudnut (18th June 2020)
  5. #3
    why dont you buy a drill bit set and cut themn to the length you need?
  6. #4
    Legendary
    194 Post(s)
    I need the unfluted section, and to be honest, cannot be stuffed cutting the end off the flute then reforming it 12 times!
  7. #5
    Legendary
    194 Post(s)
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Glad you found some. I could've sent you all my broken bits, Phil
  9. The Following User Says Thank You to mudnut For This Useful Post:
    PeeBee (19th June 2020)
