Page 7 of 7 FirstFirst ... 567
Results 61 to 63 of 63
Thread: Zd30 common rail overheating
  1. #61
    Dec 2019
    Western Sydney, NSW.
    Well after replacing the Viscosity Oil in the Fan Clutch, replacing the Thermostat, having the Radiator serviced and new tanks fitted . . . . I still had heating issues.
    My Issue ended up being the Water Pump.
    Late October 2020, I pulled the water pump off, upon getting the Fan Off the water pump had No visual leaks from the weep hole, the pump once fully removed look serviceable! No visible damage!
    After fitting new New Water Pump I've had no further Over Heating Issues since.
    ReggieRay I hope you've had some joy with your vehicle Mate.
    Grant
    Penrith Region
    Sydney NSW.
    Nov 2019
    Northern Beaches
    3 Post(s)
    I know it's hard to check without removal, but your water pump impeller may be corroded or even non-existent...
    Is there actually a way to check the state of the prop without dismantling it?
  4. #63
    194 Post(s)
    Go to Target, buy some red underpants and a blue cape, slick your hair back and take a teaspoon of Superman juice and you can look inside! Apart from that, no.
  5. The Following User Says Thank You to PeeBee For This Useful Post:
    Rossco (15th April 2021)
