Results 1 to 10 of 10
Thread: GU Motor Jingle Sound - What could it be?
    Jun 2020
    Hi all
    I've got this kind of a jingle sound near my alternator area. Today I unmounted the belt and started the engine to see if its still there or gone, but its still there. As far as I can say its not related with the engine speed. I'm not able to locate it and really wonder what it could be. Anybody's having an idea? Would really appreciate it.
    I've attached 2 videos. Its hard to record it but you should be able to hear it.
    https://streamable.com/k3rzvk
    https://streamable.com/3yec4x
    Thank you
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    My ZD was doing it also. It was the air con compressor. The front bearing was worn out.
    Easy fix
    I bought a new car
    Jun 2020
    Thanks for quick response Interesting that you experienced the same sound. I was also thinking about alternator or air con compressor pulley first. The thing is I unmounted the belt already and I could still hear that jingle sound when running the motor with no belt on. So with no belt on, the air con bearing was not able to move, in other words it cant be the air con compressor bearing, or am I wrong in some point?
    The master farter
    mudski's Avatar
    461 Post(s)
    Sounds like an exhaust leak to me. Maybe its just the crappy speaker on my work pc though...
  6. #5
    Jun 2020
    Interesting, I hope you're right and its not coming from the motor itself, will definitely check the exhaust area. In case someone experienced the same or similiar sound on the patrol, Im thankful for each hint I can get
  7. #6
    The master farter
    mudski's Avatar
    461 Post(s)
    Quote Originally Posted by braisel View Post
    Its fairly common for these motors, get a bright light and check around the exhaust side of the turbo to the exhaust manifold for soot. Also the EGR tube and the dump pipe from the turbo.
  8. #7
    Sep 2018
    queensland
    3 Post(s)
    yeh my money is on a leaking exhaust manifold (could also be egr pipe), when you rev it does the nose change at all?
  9. #8
    Jun 2020
    Okay will definitely check that area the next days. Thank you. But would it also make that kind of a jingle sound?
    No, I would say it stays the same then, not getting louder.
  10. #9
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    sounds like metal tapping metal, put pressure on things and see if the noise goes away when you apply pressure.
  11. #10
    Aug 2016
    Jimboomba
    4 Post(s)
    My old Hilux made a similar sound , turned out to be the turbo
