Page 4 of 4 FirstFirst ... 234
Results 31 to 37 of 37
Thread: GU front end clunk
  1. #31
    Mar 2020
    Yeah I put the red dexton III so very confused how it’s now black after a few hundred kms
    The master farter
    mudski's Avatar
    461 Post(s)
    You are fine to use 80/90 gear oil in the transfer case if you have manual hubs. Auto hubs need ATF to be used. Somethings definitely amiss though if the oil is black already.
  4. #33
    Mar 2020
    Well I used the ATF and it has manual locking hubs but surely that wouldn’t be causing this would it ?
  5. #34
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Yes and no. Mine was issued with Manual hubs but requires ATF.
    Wasn't it something to do with the front driveline turning while the oil was cold?
  6. #35
    The master farter
    mudski's Avatar
    461 Post(s)
    Strange. ATf was only used because of the lower viscosity, and thicker oils were tricking the auto hubs into thinking the transfer case was in 4wd.
  7. #36
    SW Vic.
    80 Post(s)
    http://www.nissanpatrol.com.au/forum...=transfer+case
    A bit of deja vu. The link to the other forum gives a good explanation about ATF too.
  8. #37
    Mar 2020
    Jacked it up and rear tail shaft off doesn’t make the noise so only happens underload
