Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: GU front end clunk
    Mar 2020
    GU front end clunk
    So my 98 GU had a bad clunking noise coming from the front end when in 4wd thought it was the CVs so though while I’m there will do a full front end rear build both sides finished all of that and still making the exact same noise sounds like it’s coming from under my feet thinking either front diff or tail shaft. The clunking starts as soon as I take off disappear for a few seconds comes back on and off please help me before it turns into fire wood 😂
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    I'm thinking it could be a seized or stiff uni joint in the prop shaft. I had a similar sensation in another vehicle and that was the culprit.
    2008 CRD Auto Wagon
    Factory snorkel, flashlube catchcan pro, 3" manta exhaust, hpd boost controller, dyno-tuned & egr deleted
    Legendary
    194 Post(s)
    Check your steering damper clamp bolts. I found I had a similar noise and they were moving a little bit on initial movement.
    Mar 2020
    Thanks for the reply’s I’ll check them out after work see how I go
  6. #5
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Sounds silly, but check your handbrake is disengaging properly. Mine had the noise manifest itself in the front drivetrain for some weird reason.
  7. The Following User Says Thank You to mudnut For This Useful Post:
    PeeBee (4th June 2020)
  8. #6
    Ballarat, Vic
    174 Post(s)
    Does it make the clunk in response to road surface. I had a terrible clunk which was only obviously on *bad* corrugations, not mild ones. Felt it through ugh the floor like you. In my case the bushes on the driver side control arm had been destroyed. Hard to see, inside the chassis, but look for the bolted end of the control arm inside the chassis, & compare it to the passenger side. If that’s it you may be lucky & just be able to tighten it up!
    A Nomadic Life (Blog)
  9. The Following User Says Thank You to Cuppa For This Useful Post:
  10. #7
    Mar 2020
    Hey it’s definitely drive line related as it in crease and decreases with speed, changes the unis no change but I tested and it only happens when the hubs are actually locked in should have done that first I know haha, they are AVM HD free wheeling my next question do they require the “egg ring” if so there is none which could be causing the issue
  11. #8
    The master farter
    mudski's Avatar
    461 Post(s)
    Quote Originally Posted by Peggy View Post
    Try only locking one side at a time. Is it only under load or coasting etc etc? Are they genuine AVM hubs or the Chinee copies? I bought Chinee copies of the Genuine Nissan free wheeling hubs and they made terrible noises. I finally forked out the coin for the real deal ones and all noises went. And no I don't believe you require the egg ring for AVMs.
  12. #9
    The master farter
    mudski's Avatar
    461 Post(s)
    Another thing to check is the diff ratio's. Make sure the back is the same as the front.
  13. #10
    Mar 2020
    Yeah mate it’s only under load if I let off or put the clutch in it goes away, will test the one locked in at a time cheers
