23rd March 2012, 01:23 PM
Will 35's fit with a 2' lift?
I was just watching one of the 4wdtv vids on here and saw a segment where they were fitting 35's to a GU and said with lift you can but need either a radius arm spacer kit or longer radius arms themselves to stop scrubbing and breaking guards, They did not however say how big the lift needs to be to start with? I run 33 MTZ's now and under big flex (for standard hight) it already scrubs. My question is, is a 2" lift enough with the Radius arms/ spacer kit enough to accomidate the 35's?????
Thanks Patroler's
23rd March 2012 01:23 PM
23rd March 2012, 01:33 PM
The 747
Probably not. My brother in law has a 3" lift in his GQ and 35s were scrubbing a little bit. Could be different on a GU but I think it's pretty similar.
The Following User Says Thank You to Winnie For This Useful Post:
23rd March 2012, 02:25 PM
Moderator
GU Wheel arches are Massive and Much bigger than a GQ. I run 35s with a 3" lift on my GUIV with no trouble at all. I have removed the front mudflaps but had to do that for the 33s and no lift. went to 35s and a 3" lift with Drop boxes instead of just spacers (same position though) and have only scraped once on a big hit
All good
Check out my Toy -->
Rogue Dung Beetle
juanpinas88 (1st September 2013)
23rd March 2012, 05:56 PM
So 3" lift required to run 35's??
23rd March 2012, 06:43 PM
Theres also body lifts and coil spacers to put into the equation.
Sent from my LT18a using Tapatalk
Hello from Under Down Under!
23rd March 2012, 06:59 PM
The Following 2 Users Say Thank You to patrol2.8 For This Useful Post:
Ben81C (23rd March 2012), juanpinas88 (1st September 2013)
23rd March 2012, 07:26 PM
So it can be done, no probs with scrubbing then? Did you just have 2" springs and shocks or coil spacers/ body blocks as well. I am put of by the price of a complete 3" kit and want to do it properly, thats why the questions about 2" lift. This way i can get a really good quality set up. I just seam to find deep ruts and i think 35's would get me through a lot of them.
Thanks, as they say a pic says a thousand words.
23rd March 2012, 09:30 PM
#8
Ben81C (24th March 2012), juanpinas88 (1st September 2013)
23rd March 2012, 10:37 PM
#9
ill be puttin on some 35s on the weekend from a mates gu ill get some pics and see where it scrubs if any and let u know.
i have a 2" lift with no radius arm spacers .
The Following User Says Thank You to megatexture For This Useful Post:
24th March 2012, 01:12 AM
#10
im running a tyre equal to a 34 with a 2 inch lift with no spacers and it does not appear to go anywhere near rubbing so id imagine a 35 should clear. Especially on a gu
The Following 2 Users Say Thank You to snowy For This Useful Post:
