Results 1 to 10 of 16
Thread: Air Ducting
    May 2020
    Air Ducting
    Hey guys this is a follow on form my last post. I am a new GQ owner and i have had a few problems and im some what sure that a vac leek is the root cause of them as you will see from the pics mine is missing the stock part called air ducting. Affter calling Nissan and 6 wreckers i have come to the concultion my only real option is to make something or adapt something. option 1 would be get a pice of the 45 bend intercooler piping from autobarn or somewhere and put 2 of thoses things for the airlines OR i see on ebay you can by that bit for a gu and im a sure ISH it would work. My GQ is going to see a machenic thursday i will check that this is the problem but i would be sure it is. When I plugged the hole it seamed to run better. And when i removed the plug eg my finger is whisteld. In a way i would like to make something i will keep you posted see pics bellow. any tips comments or problems i have missed please do tell
    May 2020
    May 2020
    the disconted hose port to the plenum98364146_259653955396568_7805812415748112384_n.jpg
    May 2020
    this is a pic from the work shop manual with the bit im trying to replce 99151568_711843689587815_8464787907943596032_n.jpg
    194 Post(s)
    looks pretty close to a 45 deg tube bend - you could contact Geordie stainless in Melb - buy a grade 304 elbow, probably cost you $20 plus shipping then go from there with silicone sleeves and hose clamps.
    462 Post(s)
    Im confused on which part you are talking about. The dodgy bit of air intake hose from the air box, or the bit with the duct tape around it.
    194 Post(s)
    Good point. I only addressed the air inlet
    It has been butchered. Has someone got a couple of pics of a standard TB42 E engine bay. I've had a quick search but can't find any.
  10. #9
    May 2020
    im talking about the part called air duct the black 45 platic bit yes the last owner made a mess of it and i want to put it rite
  11. The Following User Says Thank You to lliw180 For This Useful Post:
    mudski (20th May 2020)
  12. #10
    462 Post(s)
    Quote Originally Posted by lliw180 View Post
    So what has this part got to do with the intake duct? Does it join into said duct or something?
