Results 1 to 9 of 9
Thread: tail lights
    Jul 2010
    tail lights
    will not go fuses seem ok
    Patrol Guru Timbo's Avatar
    East Melbourne
    Check simple things like the bulbs being shot or rusty/dirty contacts for the bulbs.
    Are all of your other lights working? Have you checked the earth?
    Banned
    Do you have dash lights & front parkers? & what model do you have?
    Paul
    Aug 2010
    perth
    currently going through lights issue also, have no park lights , tail lights, fuse blows as turned on , cleaned out trailer plug, checked all plugs etc, all seem ok, all eath leads light and in good order as far as i can see. head light work , so do break lights. no dash lights...weird. does anyone know if a relay runs the park lights/tail lights ???
    Aug 2010
    perth
    damm lights !
    been trying to fault find lights issue, seem s to be common prob. no tail lights/ park lights and dash . are these all connected into one relay?? or is the coomon denominator the stalk ?? though it does seem to be in order, any one have solution?? oh do the basics, cleaned tailer plug, all connectors, earths, bulb changes etc.....i knew i shoulda stayed out of those big puddles~! oh its a 96 gq st , sweet divorce gift...
    581 Post(s)
    Hi mate, which fuse blows when you turn the car on, assuming its only 1 fuse that blows each time.
    You need to do some trial and error to isolate the problem. They would be running on the same circuit so I would go and get a handfull of fuses. dissconnect everything that runs on that circuit (tail lights, park lights, dash, etc) and then plug in each one at a time until the fuse blows again.
    Then you will know what area is causing the problem. Then you can check that part out and find a short, etc.
    You havent put a new stereo in by chance?
  8. #7
    Banned
    Quote Originally Posted by dougydoug View Post
    This is common in Patrols & yes I would say its a 90% chance its your headlight switch (stork) but its not the stork itself its a switch in behind & its serviceable.
    So what are you DIY skills like ie. could you fit your own car stereo? If the answer is yes than I can talk you through the rest.
    Paul
  9. #8
    Banned
    Sorry just read your first post???? Have you fitted or have you had a new stereo fitted of late?
  10. #9
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    I found I had no interior light, horn, tail light & dash. Replaced fuse all good. Not sure what caused fault. So, if GQ is same check front park lights haven't rubbed through. Have you added driving lights to the circuit?
