1st July 2011, 09:52 PM
I've never seen the correct tool if there is one. A 1/2" breaker bar is all I have ever used, it's not the right size but it does the job. Always take the fill plug out first, you don't want to get caught with the oil drained out and no way to refill it.
Tony
The Following User Says Thank You to YNOT For This Useful Post:
1st July 2011 09:52 PM
1st July 2011, 10:02 PM
1st July 2011, 10:54 PM
what kind of k's are on ya truck???? might want to change the o2 sensor (bosch part number 0 258 986 501) there a single wire sensor and should be changed every 80,000kms
The Following User Says Thank You to Peacemaker For This Useful Post:
10th July 2011, 05:31 PM
You guys are awesome. Just a follow up on the diff/transfer socket thingy. Found Company in USA called Ultimate tool co. They have a 13mm square socket for diff and a 17mm for transfer fill. Made in Japan for Nissans! Cost landed is $30.ooea AUD. I'll tell you how they go.
The Following User Says Thank You to PT Paul For This Useful Post:
31st July 2011, 04:45 PM
used the 13mm socket from ultimate tool co and it works perfect.
