Results 1 to 7 of 7
Thread: GQ Patrol - No Keys
    Apr 2020
    GQ Patrol - No Keys
    Hi Team,
    I just purchased a "Project" 97 Patrol RX Turbo Diesel..its in need of a fair bit of work. I had it transported to my garage , the previous owners have lost keys...so the first job is...either change ignition barrel/key or is it possible to get key cut to suit ?...cheers in advance for any info.
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    either way the barrel has to come off, so find a cheap second one or take barrel to key cut place to get a replacement key for that barrel and hope they don't change the key format /foot print, that way you can you it for other doors on the patrol
  4. The Following User Says Thank You to altech For This Useful Post:
    Kiwi1968 (28th April 2020)
    Jan 2018
    Pt Augusta SA
    most qualified locksmith can make a key to fit the ignition unless its too worn. If it was one key to suit all locks then it will still fit all locks.
    Pete
    Jan 2018
    Pt Augusta SA
    most qualified locksmiths can make a key to fit the ignition unless its too worn. If it was one key to suit all locks then it will still fit all locks.
    Pete
    74 Post(s)
    Get locksmith to re-key the locks so the old "Lost" keys can't be used.
    398 Post(s)
    Ask Nissan for the lock codes then go to a real locksmith, not a Mr.Minute, and they can cut new keys by the code. I did this with my own Patrol.
    Yeti's Beast (23rd April 2020)
  10. #7
    Apr 2020
    Thanks Pete
