Results 1 to 5 of 5
Thread: Signal wire for brake controller.
    Patrol Guru
    May 2011
    mackay former alice boy
    Just getting peoples ideas ;I need a signal wire or pulse wire that tells the controller the brakes are on so it can send power to the trailer brakes .I'm using the switch on the brake pedal and get a reading from the red and yellow wire when the brake is activated is this the best place to splice in whats your thoughts.
    Sep 2011
    adelaide
    18 Post(s)
    Mate yes it is the best place just make sure you splice on to the BRAKE light switch and not the CRUISE control switch .
    An other hint run all earths back to the battery, don`t just earth out to the body .
  4. The Following User Says Thank You to pearcey For This Useful Post:
    dads tractor (10th April 2020)
    Patrol Guru
    May 2011
    Thanks mate she's an old girl 99 so no flash stuff here. All accessories are going back to a earthbar and across to the neg terminal on primary battery in wire tidy up. cheers
    Sep 2011
    adelaide
    18 Post(s)
    Quote Originally Posted by dads tractor View Post
    Forgot to mention, if possible bring the earth wire for the trailer , caravan, back to the car battery.
    99% of electric brake problems are earth related. Running that extra wire will save you from many problems in the future.
  7. The Following User Says Thank You to pearcey For This Useful Post:
    pollenface (11th April 2020)
  8. #5
    Patrol Guru
    May 2011
    thanks Cobber wil be running 12 gauge return from trailer that should cover it aye.
