Results 1 to 6 of 6
Thread: What diff do I have?
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    I naturally assumed it to be the H260 wagon LSD varient with 4.7L capacity, but when I changed the diff oil I was surprised to see it not taking more than 4L (3.7 seems approximately right).
    Now I'm wondering if it's a H260 with factory diff lock. There's nothing in the cab to indicate having a diff lock.
    This is my first patrol since December last year, still learning about it.
    Here's a list of diffs from the 2007 manual
    2008 CRD Auto Wagon
    330 Post(s)
    Quote Originally Posted by pollenface View Post
    The detail will be on your compliance plate on the fire wall under the bonnet
    How many bolts holding the diff centre in? 11 or 12. 11 is the H233 and 12 is the H260. If you have a diff lock you will have a large control diaphram with a rubber hose attached, mounted to the diff centre.
    tryan277 (9th April 2020)
    Advanced tryan277's Avatar
    May 2016
    Melbourne, Southern Burbs
    Mudski
    Another little gem of information... 11 or 12 bolts then you know which diff it is.... instead of relying on the original build plates attached to the vehicle.
    Cheers Trevor
  7. The Following User Says Thank You to tryan277 For This Useful Post:
    mudski (10th April 2020)
  8. #5
    Nov 2019
    Perth
    5 Post(s)
    Thanks for the info, I'll have a look when I get home in 13 days!
    2008 CRD Auto Wagon
  9. #6
    Nov 2019
    Perth
    5 Post(s)
    Turns out it's an 11-bolt diff with out locker.
    Thanks.
    2008 CRD Auto Wagon
  10. The Following User Says Thank You to pollenface For This Useful Post:
    mudski (28th April 2020)
