Results 1 to 9 of 9
Thread: gu patrol window winder
    Apr 2020
    Hi all, my name is rob from wa and I am new to this site. I have a 98 patrol. I need to replace the drivers side (front) manual window winder. having a little trouble finding one. can someone please tell me if the rear rhs passenger door mechanism is the same as the front. I have access to one if it fits. kind regards, rob
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Take the rear one off, compare it with the front one, try it on the front door and see if it fits.
    Apr 2020
    thanks bill. I did consider doing that but Im worried that I might ruin the good one. also not an easy job. I was hoping that someone might know before I attempt that. thanks for reply. Rob
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
  6. #5
    Apr 2020
    Thanks Dhuck. Great forum, lots of friendly members
  7. #6
    Jul 2010
    Thurgoona
    7 Post(s)
    Haven't had a car with a window winder for many years - but I remember you can buy a simple and cheap tool in most auto shops that you poke in behind the handle to easily remove it by pushing the retaining clip out.
  8. #7
    The master farter
    mudski's Avatar
    462 Post(s)
    Front RHS door manual reg is part number 80720VB000, and the rear RHS manual reg part number is 82720VB000. So to answer your question, no they are not the same and won't interchange. Well going by the part numbers they won't...
  9. #8
    Apr 2020
    Thanks so much for that info. yes that does answer my question... I have taken the front winder out. the teeth on the spindle have worn. probably a common fault with most manual door winders on any vehicle. I remember fixing one on my fj holden 40 years ago. I will break it open and just replace the shaft . Thanks again. Big help
  10. #9
    Apr 2020
    thanks Bill. that was the easy bit. got that clip off with a screwdriver. problem with the handle winder shaft. (stripped teeth) working on that project now. thanks again for your help. cheers
