Results 1 to 1 of 1
Thread: GU tacho
    Oct 2019
    Murray Bridge SA
    GU tacho
    Hi I’ve got my conversion up and running (TD42T into ZD) and just wondering what everyone’s thoughts are on the Dakota digital tacho correction units. I got Killa Kustom Kables to make the loom for me and they did a great job, plugged it in and turned the key and it ran. The thing is that with the converter set to 6 cylinders in and 4 out like it was set and the instructions say it didn’t even register at idle and out on the road I could only get it to about 1500 rpm on the gauge. I have played around with it and the closest I can manage to get it to reading true is set at 5 in and 6 out but it’s still not quite right according to what rpm I used to have at 100 kph. It also seems to be slow to respond and the needle is a bit jumpy. I tried to call Killa kustoms but haven’t been able to get through to quiz them just thought I’d ask if anyone else has had similar issues? Cheers.
