Results 1 to 6 of 6
Thread: How much psi can RD28T can handle
    Jan 2020
    Hi guys, I have w260 1993 2.8TD original engine and original turbo. I want to connect a intercooler to the original turbo and after that I will hybrid my turbo by changing spinnings. But how much psi can the engine take before blow up ?
    136 Post(s)
    Impossible question to answer, somewhere between 15 and 1500PSI at a guess. What condition is the motor, how many klm, how is it driven, how is it maintained, what ambient temps do you have? I think there is a guy in the UK who is a hard core 2.8 Turbo guy - google him. I had that engine in a Y60 - GQ and it ran at 12psi from factory. It spins up smooth and quick but to be honest its a little motor for a big vehicle so I would not be stressing it too much if you want it to last
    Manufacturer of the Complete Camp Oven System
    Website:http://davesstuff.net/
    Vendor Page: http://www.nissanpatrol.com.au/forum...ar-That-Works/
    Tuturial Video's: http://www.nissanpatrol.com.au/forum...ted-on-Youtube
    66 Post(s)
    Before going full blast at modifying your engine, have a look at this thread:
    http://www.nissanpatrol.com.au/forum...hings-to-check
  5. The Following User Says Thank You to mudnut For This Useful Post:
    PeeBee (28th March 2020)
    Jan 2020
    The car is 382.000 km but the motor is okey. thank you by the way
    Jan 2020
    @PeeBee do you know which turbo did he use? It is not written there.
    136 Post(s)
    Quote Originally Posted by sarngon View Post
    Unfortunately no. It was recommended to me to change the turbo from the factory unit to a ball bearing unit however I didn't go that way as ended up changing the motor out instead. I think there are a number of options out there from turbine wheel swaps to complete turbo's. The guy in the UK runs a highly modified engine with a pile of strengthening I believe. I doubt you are going to get significant power and longevity out of a straight turbo swap, look at pump and injectors, maybe head works? The mileage would also be a potential area to consider as its getting on. I know this is a mid range mileage for the TD42 engine however think the RD28 probaly does not have the same degree of engineering margin to take high stress. I found blocking the EGR gave me a little bit of lower rpm boost, I upgraded the air filter to the safari snorkle and its big filter box - and ran a re-oil-able K&N filter - this made the biggest leap in performance as the engine could breath, and added a safari intercooler - air to air front mount, it made a little bit of difference performance wise, nothing startling, bang for buck not worth the money, however perhaps a bigger intercooler core would have helped
