Results 1 to 6 of 6
Thread: 1998 GU TB45 Radiator sensors
    Mar 2020
    Just wondering if someone with a GU TB45 engine could check whether they have a sensor fitted to the driver’s side bottom radiator tank, and if this sensor is connected to the main wiring loom.
    I had the original radiator replaced several years ago by a local shop, and only recently when replacing the bottom radiator hose, noticed the replacement radiator had a sensor fitted to the driver’s side of the bottom tank with a short length of wiring ending in the female half of a connector, with no wiring in the vicinity to connect to. Could be a fitment for another model? Many thanks,
    bobmac1
    49 Post(s)
    I'll have a look during the course of the day.
    49 Post(s)
    Had a look mate.
    I'm running a cheap aftermarket unit have had it for a few years now. Looks like a drain plug same as the one on the other side. I don't ever recall seeing any wiring loom around that area while it's been out.
    Maybe someone has fitted a temp sensor..
    Mar 2020
    Hi jay see,
    Thanks for taking the trouble. I suspected that the sensor was superfluous, as have never had overheating issues or A/C problems. It’s small details like these that the aftermarket manuals fall short on. It is probably covered in the genuine Nissan manual, but when I bought the vehicle secondhand in 2000, they wanted about $700 for one! Thanks again,
    bobmac1
  6. The Following User Says Thank You to bobmac1 For This Useful Post:
    jay see (21st March 2020)
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    There’s no reason for a TB45E to have a temp sensor in the radiator. The overheat switching of the electric fan and the overheat A/C cutout are all controlled by the ECU which reads the temp sensor next to the gauge temp sensor on the thermostat housing.
    John
    Mar 2020
    Hi John,
    Many thanks for your reply.
    bobmac1
