6th April 2012, 07:44 AM
Cheers for the info. By process of elimination, I think my problem is also electrical.
tappn it
Hello from Under Down Under!
6th April 2012 07:44 AM
6th April 2012, 10:35 AM
NissanGQ4.2
did you get a refund on the box you bought off ebay????
No, the guy sounded genuine. He was a bit unsure when I asked him to take the sump off to photograph the inside of it for me, he was worried about wrecking the gasket on it. I don't think he did anything wrong, and would've had the same problem I did, if he'd used it in his project.
taslucas
tappn it
Sounds like it. Now comes the challenge of narrowing down which electrical component.
Mine was really frustrating, but once I got that error code, and followed Nissan's troubleshooting process, it all worked out.
1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
6th April 2012, 10:50 AM
The box changes perfectly(way better than standard with the aftermarket valvebody). I have all gears etc. It's just the lockup TC that drops in and out at 90 to 100 km/h. And only when its really warmed up (after 20/30 mins of driving) so hopefully it has to do with the temp sensor.
Another strange thing is if I get straight onto the highway I can drive for over an hour at 90/110 km/h and it won't play up. But if I drive around country roads it starts to play up after 20 mins or so ?
tappn it
6th April 2012, 10:56 AM
Banned
The Following User Says Thank You to Bigrig For This Useful Post:
6th April 2012, 11:31 AM
taslucas
Hopefully you're right.
That was the first problem with ours. Since the box was reco'd, it hasn't done that at all.
No idea what was causing ours to do that before, but Nissan's guide in their service manual was what fixed ours in the end.
6th April 2012, 01:18 PM
ripper
The most common cause of the TC lockup dropping in and out is a worn out TC.
95% a reco TC fixes it (if the box is still in good condition)
tappn it
The Following User Says Thank You to taslucas For This Useful Post:
