Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Anyone rewired a rev sensor in a GQ automatic?
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Cheers for the info. By process of elimination, I think my problem is also electrical.
    tappn it
    Hello from Under Down Under!
    Expert ripper's Avatar
    Leeton NSW
    did you get a refund on the box you bought off ebay????
    No, the guy sounded genuine. He was a bit unsure when I asked him to take the sump off to photograph the inside of it for me, he was worried about wrecking the gasket on it. I don't think he did anything wrong, and would've had the same problem I did, if he'd used it in his project.
    tappn it
    Sounds like it. Now comes the challenge of narrowing down which electrical component.
    Mine was really frustrating, but once I got that error code, and followed Nissan's troubleshooting process, it all worked out.
    1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
  4. #13
    Aug 2011
    North West Tas
    56 Post(s)
    The box changes perfectly(way better than standard with the aftermarket valvebody). I have all gears etc. It's just the lockup TC that drops in and out at 90 to 100 km/h. And only when its really warmed up (after 20/30 mins of driving) so hopefully it has to do with the temp sensor.
    Another strange thing is if I get straight onto the highway I can drive for over an hour at 90/110 km/h and it won't play up. But if I drive around country roads it starts to play up after 20 mins or so ?
    tappn it
  5. #14
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Top write up old mate!!
  6. The Following User Says Thank You to Bigrig For This Useful Post:
    ripper (6th April 2012)
  7. #15
    Leeton NSW
    Hopefully you're right.
    That was the first problem with ours. Since the box was reco'd, it hasn't done that at all.
    No idea what was causing ours to do that before, but Nissan's guide in their service manual was what fixed ours in the end.
  8. #16
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by ripper View Post
    The most common cause of the TC lockup dropping in and out is a worn out TC.
    95% a reco TC fixes it (if the box is still in good condition)
    tappn it
  9. The Following User Says Thank You to taslucas For This Useful Post:
