Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Patrol GQ auto convertor lockup
    Nov 2010
    hi, I found this link with information about manual torque convertor lockup on a GU Patrol. Is the wiring the same to the GQ patrol TCU? (Same pins/wire colour)
    http://www.chaz.yellowfoot.org/Locku...s%20Switch.htm
    1981 Nissan Patrol MQ SWB, 3.3TD, West Melbourne.
    Expert Chaz's Avatar
    Sep 2010
    Adelaide
    Hi Boggy,
    No it's not the same. I think from memory the Y60 used pin number 21 on the TCU for the lockup solenoid. You would need to check it with your manual because some other models were different also. The circuit will work on a Y60, but you can't lock your converter in 1st gear unless you use a GU valve body. In some ways thats better because you don't have to worry about the brake pedal release to unlock it unless you have the HOLD switch on.
  4. The Following User Says Thank You to Chaz For This Useful Post:
    boggy2006 (4th February 2011)
    Nov 2010
    hi, that's great thanks, I'll look into it.
    When you say that it can't be locked up in 1st, does that mean if I try to it will break it, or it just won't lock up even if the lock up solenoid is active?
    Expert Cadbury's Avatar
    Nov 2010
    Waterford QLD
    Hi all
    Does this prevent run away on a steep down hill,
    If so can you do this to a 1999, 4500 auto bow?
    Cadbury
    Quote Originally Posted by boggy2006 View Post
    It just wont lock up in first, it wont damage anything.
    Tony
    Quote Originally Posted by Cadbury View Post
    Hi all
    Cadbury
    Yes it does reduce runaway and yes it can be done on a '99 4.5 auto.
    Tony
  9. #7
    Nov 2010
    That's good, thanks. I guess it means it won't stall the engine then when stopping in 1st with it locked up. What happens if you try to drive through the gears normally (with it in D) with it locked up all the time? Would it work? Do I have to try it ;-) ?!!
    ps. according to the workshop manuals on here, it looks like pin 22 for the GQ. Pin 21 is the overun solenoid with only activates in 1st, 2nd, 3rd which I beleive is why the revs drop and it virtually free wheels when you take your foot off the accel in 4th. Might be nice to have that operating in 4th too.
    I'm also wondering if there's anything that can be done with my sloppy 2nd-3rd change. Firstly checking the shift A and shift B solenoid coil resistances and when they operate during the 2nd-3rd shift, if they are PWM'd etc.
  10. #8
    Hi Cobber,
    I did this mod to mine and subsequently a couple of others and it was one of the best things I did to the old girl.
    To clear up a few things...
    Firstly... the TC will lock in first gear but unlike the GU's that will stall if you come to a complete stop the GQ has a lower pressure valve body and will "buck" a little bit but not stall however still not a recommended practice. Braking to a complete stop with it engaged that is.
    Second... ECU pins. You are correct it is pin 22 for all the GQ's I have done but the wire colour code changes between a few models. See my posts here: patrol4x4.com/forum/nissan-patrol-gq-y60-ford-maverick-11/94-gq-auto-tranny-lock-up-switch-8860
    NOTE: Direct link removed as patrol4x4 are currently experiencing virus / malware issues, view the link at your own risk.....Regards, Forum management
    Third... there are pics floating around that have the Engine and Tranny ECU locations mixed up. The Tranny ECU is behind the passengers kick panel in the LH side of the Pass footwell, well, again at least in all the GQ's I have done. The best spot to put the relay IMHO is above the ECU so do that while you are in there
    Now for the advantages/disadvantages
    Advantages and a couple of them are BIG ones IMHO
    1. Heaps better engine braking in downhill descents off road.
    2. Significantly lowers Gearbox Temps when towing as the TC slippage is one of the main heat sources
    3. It sort of gives you split gears between Drive TC locked and Drive TC unlocked (esp when towing) and same for O'drive so makes the hills easier to negotiate on the open road.
    4. Better fuel economy on-road in daily driving if you do a lot of 70 to 80 KPH stuff.
    Disadvantages only minor IMHO
    DON"T lock up the TC under power IE lift the pedal and lock it or lock it prior to descent.
    When locked you drive it like a manual tranny and again just lift the pedal momentarily as you change gears. There is no need to disengage the TC lockup if you do that, you can just leave it locked and only disengage when stopping.
    ET's thoughts
    I reckon it is a cracking mod and can be done for under $20 depending on how "techo" you make it with brake realys speed sensors etc adding to the cost. It totally changed my truck and I did the best part of 100,000 K's touring, towing the Camper and 'wheeling with no issues whatsoever
    I just had an old floor mounted "dip switch" for the left foot to engage/disengage, a single pole switch on the dash to "arm" the floor switch and a 12 Volt LED under the switch to tell me if it was "locked"
    Finally... Kudo's to Chaz for putting the idea and original circuits up.
  11. The Following User Says Thank You to the evil twin For This Useful Post:
  12. #9
    Nov 2010
    Thanks for the info. It would be great if it was possible to detect a shift then release lock up for the shift, I wonder if shift solenoid A and B could be monitored and used to detect a shift, if they are responsible for the shifts. Also need vehicle speed below a certain value eg. 15kph, then remove lock and revs above a certain value eg. 1800rpm, to engage lock, how about a paddle shift!! Might as well make another ECU whilst I'm at it LOL!! Could do it as I'm an electronics engineer, but it's just finding the time (screaming wife/kids, full time job, not enough holidays etc etc!!).
  13. #10
    Expert ripper's Avatar
    Leeton NSW
    ET's thoughts
    Old thread I know, but were you towing the camper in D or 4th?
    Just trying to work out how much weight you can safely tow in OD.
    1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
