Results 1 to 8 of 8
Thread: Drain oil from top of motor?
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    Need to fill in my knowledgebase.
    If I put the Patrol on it's side or upside down, could oil run into the top of the motor?
    If so, does it help if I remove the glow plugs and turn it over to remove the oil?
    If so, how do I go about that and do I need any special tools?????
    Thanks.
    Jun 2018
    24 Post(s)
    Thanks.
    Geez, you're going to need some special tools if you want to turn your Patrol upsidedown! If you want to do it in a controlled fashion that is...
  4. The Following User Says Thank You to Cremulator For This Useful Post:
    10G (6th March 2020)
  5. #3
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    I was born with those tools, feet, arms, hands and deranged mind.
  6. #4
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    If it is upside down for a long enough period, oil will drain past the rings, into the combustion chamber, past an open valve, into the inlet plumbing. It will also rapidly fill the tappet cover. Once back on its feet, it will drain from the tappet cover, but due to lack of pressure, (oil level) it will mostly stay in the combustion chamber.
    Removing the glowplugs; then cranking the engine should clear the top of the pistons. If you don't do that, you risk bending a rod from hydrolock.
    You would also have to clear the inlet plumbing. I don't know long it would take to affect the turbo from oil getting past an open inlet valve, though.
  7. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    10G (6th March 2020), mudski (5th March 2020)
  8. #5
    Expert Mickhead's Avatar
    Oct 2019
    2 Post(s)
    Maybe treat it like a fridge? If its been on its side for 2 hours stand it up for 4 before you restart it? .
  9. The Following 3 Users Say Thank You to Mickhead For This Useful Post:
    10G (6th March 2020), mudnut (5th March 2020), Rossco (7th March 2020)
  10. #6
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    If it is upside down for a long enough period, oil will drain past the rings, into the combustion chamber, pat an open valve, into the inlet plumbing. It will also rapidly fill the tappet cover. Once back on its feet, it will drain from the tappet cover, but due to lack of pressure, (oil level) it will mostly stay in the combustion chamber.
    Thanks Craig. How/why would it affect the turbo? I know the turbo needs oil, wouldn't it just suck oil up as it would normally??
  11. #7
    SW Vic.
    80 Post(s)
    I suspect that if the geometry allowed oil to get to the turbo it would coat the inlet blades, most likely unevenly. I don't know where your EGR is plumbed into the system, but sticky turbo blades and EGR soot aren't a good combo.
  12. The Following User Says Thank You to mudnut For This Useful Post:
  13. #8
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    And possibly uneven oil coverage on the blades could unbalance the turbo and blade could end up meeting casing???
