Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: ZD30 CRD Belt tensioner pulley.
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    I have had and aftermarket set of front belts from SeatSafe https://www.seatsafe.com.au/ for around 10 years and they work perfectly (like any normal seat belt should). I have aimed a number of people in their direction and all are happy. Only problem I had was their data base shows Patrols have belts with pre tensioners. Mine does not - so I called them and just asked for a normal non pre tension belt for a Patrol and it works great. Only difference is between wagons and utes. Search this site for previous threads.
  2. The Following User Says Thank You to BillsGU For This Useful Post:
    10G (4th March 2020)
    May 2016
    lower west victoria
    30 Post(s)
    Good to know, thanks Bill.
  5. #13
    Jul 2010
    Thurgoona
    7 Post(s)
    Sorry guys! I lost the plot and completely miss read the post. I thought you were talking about seat belt tensioners ................................
  6. The Following User Says Thank You to BillsGU For This Useful Post:
    growler2058 (19th April 2021)
  7. #14
    May 2016
    lower west victoria
    30 Post(s)
    Hey that's OK, you contributed some useful info.
  8. #15
    175 Post(s)
    Think I don't need to reiterate what's been said above. But , stuff it I'll do it anyway.
    Genuine assembly. Genuine assembly.
    There... I done it.
    3 year ownership of a crd zd30 and I've chewed through 2 of them units.
    Yes ,many river crossings and high country dust might have contributed ...
    Beginner ausssiefan's Avatar
    Jan 2020
    The bushes flog out and the shockie thingo loses its tension. The genuine bearing in those are double row and a stupid width too, you can't buy the exact same bearing. The aftermarket tensioners use a single row bearing, they work but wont last. Been down this road many times before. The best thing is to buy an OEM tensioner, and an aftermarket as a spare and keep this under the passenger seat.
    Don't get me wrong - the bearing from WC87503 NTN is devinitly just a one row bearing, according to their homepage and drawings. Dimensions are ID 17 mm, OD 40 mm, total width 14.288 mm.
  10. The Following User Says Thank You to ausssiefan For This Useful Post:
