Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Old patrol roof rust repairs
  1. #21
    Sep 2019
    New Zealand
    3 Post(s)
    Quote Originally Posted by PureCaboose View Post
    It's amazing how much time we don't have when in quarantine (not that it changed anything for us, if anything we go out more. sigh)
    Yup... I work in IT so I am able to work from home pretty easily. Combine that with a senior management team that are bored senseless as a result of the lockdown, and it's very easy to get buried in more work than you would have otherwise.
    Sep 2019
    New Zealand
    3 Post(s)
    Some more progress...
    Finished welding in and grinding back a patch:
    Complete with some primer:
    Marked out some steel:
    Then chopped it up:
    I did three of these in total, then ran them through the bender and welded them end to end.
    The end result is too long to easily take a photo of, but it should be welded to the side of the frame rail in due course.
    Cleaned up the rear of the thing - removed what remained of the rear gutter and marked out the bit I need to cut out and patch:
    I ground off the rust in the good areas and gave them a shot of primer, but it was too dark to get a good photo.
    The next task is the back corner. A bit rusty...
    I'll have to fabricate and weld in a temporary support for the roof frame before I chop that lot out.
  4. The Following 2 Users Say Thank You to Nhoward For This Useful Post:
    0-TJ-0 (18th May 2020), Sherro (16th May 2020)
  5. #23
    136 Post(s)
    You are amazing, brilliant work, top stuff
    Manufacturer of the Complete Camp Oven System
    Website:http://davesstuff.net/
    Vendor Page: http://www.nissanpatrol.com.au/forum...ar-That-Works/
    Tuturial Video's: http://www.nissanpatrol.com.au/forum...ted-on-Youtube
  6. #24
    Sep 2019
    New Zealand
    3 Post(s)
    Time to do something about the rear right corner of this thing...
    Welded in some temporary support struts:
    Removed the rusted bit of the existing support, removed the remains of the gutter and marked out the intended path of the body saw:
    Marked out the cut on the rear:
    A few moments with the body saw... no more rust, but some big holes to patch:
    Test fitted the gutter I fabricated earlier:
    Needs to be another 250mm longer, but looks like it'll work.
  7. The Following 3 Users Say Thank You to Nhoward For This Useful Post:
    0-TJ-0 (18th May 2020), mudnut (18th May 2020), Rossco (17th May 2020)
