Results 1 to 6 of 6
Thread: GQ 1993 stock steering wheel
    Beginner Convert's Avatar
    Dec 2019
    These things are not as abundant as I expected them to be.
    Im looking for a good one in NZ
    If the rubber has separated from the steel ring, it is repairable.
    Expert Arfa Brayne's Avatar
    Jul 2016
    Drill a 1/16th hole in the rubber where it has come away at one side, and another hole on the other end.
    Use a syringe to inject polyurethane liquid adhesive until you can feel it's all the way through.
    Wrap a damp cloth around the repair area and leave for a day or so.
    If you use too much adhesive it will take too long to set and not be as strong.
    "Can't" is a dirty 4 letter word.
    Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
    Sip on the "t", and consider what you've got left to work with
    Dec 2019
    This truck has a little Momo in it and it blocks out the view of the gauges
    Jul 2016
    Quote Originally Posted by Convert View Post
    In hindsight it might have been better to state this at the START of the topic.
    Can't help you.
    Nissan Pulsar N14 (and I am told N15 but haven't used one myself) bolt straight up and are slightly smaller than stock but should be bigger than the Momo.
    I have put the N14 Pulsar Wheel on a couple of GQ's and no panel visibility issues but will depend on driving position.
    In NZ I would have thought there should be 100's of Pulsar Steering Wheels around so maybe that is an option.
  8. The Following User Says Thank You to the evil twin For This Useful Post:
    Convert (24th February 2020)
