Results 1 to 10 of 10
Thread: HF Radio and Joolca Hot Tap
    BiPolar Fool BSRT.Beast's Avatar
    Apr 2015
    Keysborough
    4 Post(s)
    66 Post(s)
    Links go to nowhere, mate.
    BSRT.Beast (13th February 2020)
    Apr 2015
    Keysborough
    4 Post(s)
    Hmm that sucks I'll try again lol
    Apr 2015
    Keysborough
    4 Post(s)
    http://ebay.us/inhn94?cmpnId=5338273189
    Apr 2015
    Keysborough
    4 Post(s)
    http://ebay.us/s7Pxla?cmpnId=5338273189
    Apr 2015
    Keysborough
    4 Post(s)
    Try those .... ???
  9. The Following User Says Thank You to BSRT.Beast For This Useful Post:
    mudnut (13th February 2020)
  10. #7
    122 Post(s)
    So no more hot showers a long way rom anywhere then?
    2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, 240v, 3 Genie exhaust + dynotune, 2 lift, Lovells GVM upgrade, ROH Blaktrak steel wheels, Bridgestone D697s, Redarc gauges/pillarpod, Hema HX-1, CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, Tyredog TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare)
    A Nomadic Life
    The Big Trip Blog
  11. #8
    Apr 2015
    Keysborough
    4 Post(s)
    Changing to a Glind underbonnet heaps more suited for our needs and the TD doesn't need much to heat it up lol.
  12. #9
    122 Post(s)
    Quote Originally Posted by BSRT.Beast View Post
    Have you used a glind. I had one once & found the process of running the motor whilst showering & mucking around with heater controls a bit of a pain. What I have now may or may not suit you. Water is heated in the same way as the glind heats it, but does so in a larger insulated vessel. We arrive at camp with 22 litres of water at engine coolant temp, & a tempering valve adds cold water as we use it set to the temperature we want, which makes the 22 litres go much further. 20 to 30 minutes drive is sufficient to bring cold water up to good shower temp. However we cant keep the hot water going indefinitely as you can with the Glind or Joolca (if you have the water supply), but what we do have is a user settable very stable temperature. Depending upon ambient temps, the water remains hot enough to shower with for two to 3 days.
    A Nomadic Life
    The Big Trip Blog
  13. The Following User Says Thank You to Cuppa For This Useful Post:
  14. #10
    Apr 2015
    Keysborough
    4 Post(s)
    Yeh I've read about that style but with space being very limited I think the glind style would suit us better, yeh they can be fiddly but it's something we'll deal with.
  15. The Following User Says Thank You to BSRT.Beast For This Useful Post:
    Cuppa (14th February 2020)
