Results 1 to 10 of 10
Thread: HF Radio and Joolca Hot Tap
    BiPolar Fool BSRT.Beast's Avatar
    Apr 2015
    Keysborough
    4 Post(s)
    Links go to nowhere, mate.
    BSRT.Beast (13th February 2020)
    Apr 2015
    Keysborough
    4 Post(s)
    Hmm that sucks I'll try again lol
    Apr 2015
    Keysborough
    4 Post(s)
    http://ebay.us/inhn94?cmpnId=5338273189
    Apr 2015
    Keysborough
    4 Post(s)
    http://ebay.us/s7Pxla?cmpnId=5338273189
    Apr 2015
    Keysborough
    4 Post(s)
    Try those .... ???
  9. The Following User Says Thank You to BSRT.Beast For This Useful Post:
    mudnut (13th February 2020)
  10. #7
    174 Post(s)
    So no more hot showers a long way rom anywhere then?
  11. #8
    Apr 2015
    Keysborough
    4 Post(s)
    Changing to a Glind underbonnet heaps more suited for our needs and the TD doesn't need much to heat it up lol.
  12. #9
    174 Post(s)
    Quote Originally Posted by BSRT.Beast View Post
    Have you used a glind. I had one once & found the process of running the motor whilst showering & mucking around with heater controls a bit of a pain. What I have now may or may not suit you. Water is heated in the same way as the glind heats it, but does so in a larger insulated vessel. We arrive at camp with 22 litres of water at engine coolant temp, & a tempering valve adds cold water as we use it set to the temperature we want, which makes the 22 litres go much further. 20 to 30 minutes drive is sufficient to bring cold water up to good shower temp. However we cant keep the hot water going indefinitely as you can with the Glind or Joolca (if you have the water supply), but what we do have is a user settable very stable temperature. Depending upon ambient temps, the water remains hot enough to shower with for two to 3 days.
  13. The Following User Says Thank You to Cuppa For This Useful Post:
  14. #10
    Apr 2015
    Keysborough
    4 Post(s)
    Yeh I've read about that style but with space being very limited I think the glind style would suit us better, yeh they can be fiddly but it's something we'll deal with.
  15. The Following User Says Thank You to BSRT.Beast For This Useful Post:
    Cuppa (14th February 2020)
