Results 1 to 7 of 7
Thread: Weird noise GU
    Aug 2019
    Weird noise GU
    hey everyone I cant seem to find this unique noise that's coming from my engine bay, it happens in the morning when I leave for work or when the engine has cooled down or has stopped for a while and it eventually goes away usually after 5-15ish minutes of driving I first noticed the noise about about 2-3 weeks ago. I haven't had a loss of power and the car seems to drive fine to be honest, the noise appears about 3k-4.5k rpms
    Most recent things I have done to my patrol is I've changed the intercooler and pipes about 4 months ago, noise wasn't there when I replaced the intercooler and pipes and I have tighten all bolts again. I've replaced my catch can from a hpm to a provent about 3 months ago.
    Now details about my patrol, its a 2011 zd30 common rail has done about 260k kms on it, car hasn't been fitted with any gauges yet, I know I'm not loosing any power. If anyone has had this issue or knows roughly what it could be please let me know.
    Here's a video link of the noise too
    https://youtu.be/eo17bFmJePU
    Expert Mickhead's Avatar
    Oct 2019
    My 03 zd30 used to scream like a angry cockatoo when cold, only for a few minutes, related to revs and boost. Loose exhaust manifold nuts. Only 2 of them. Tightened them, noise gone.
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Mine was intercooler pipe clamps not tight enough. Very similar noise and symptoms to exhaust leak.
    I see you say you've checked them.. So had I. I ended up making up a very rudimentary bung to pressure test the whole system. About 40% of my joints were leaking(new system) and I had to tighten them way past what I thought would be reasonable. I'll bet my bottom dollar if it's a squealing type noise and you've played with intercooler pipes that's what it is.
    sunshinecoast
    possibly a warped inlet manifold ? or cracked egr pipe ?
    462 Post(s)
    Quote Originally Posted by nipagu7 View Post
    on-thehead-nail-you-have-32807617.png...............
    175 Post(s)
    My money is on the egr pipe behind the motor.
    Advanced Lionel84's Avatar
    Feb 2013
    Brisbane, QLD
    Sounds like a blower ribbed belt
    Sent from my SM-G975F using Tapatalk
    2007 Nissan Patrol Y61 Wagon AT 2009 ZD30CRD Engine
    Snorkel, Tillex, HPD Intercooler, 3" King Brown Exhaust, 2" Bilstein Lift, Steel Bar and 12000lb Winch, Engine Bay Lighting
