Page 15 of 15 FirstFirst ... 5131415
Results 141 to 142 of 142
Thread: 3.0lt GU Patrols - Grenade Facts
  1. #141
    Aug 2019
    Thinking about getting a 2003 ST 3L but reading a lot about the "grenade" issue. Will have a read through this forum but if anyone has any sage advice that would be very welcome Cheers. Ben
    461 Post(s)
    Quote Originally Posted by bjcresswell View Post
    Its no denying that this is a real issue. There is plenty still going around with 300plus thou on the clock and not using a drop of oil.
    Try and buy something that has already been rebuilt, or as low as possible k's on it. Even a rebuild is no guarantee you are safe. I bought mine with a 40k old motor, 50ísh though later the IP died. I ended up doing a TD swap, removed the head on the ZD and number 4 piston was cracked and ready to go. I have said to other people if you buy a 3Ltr, expect it to drop the pin, if it doesn't then great! They are a good little zippy motor. Good if you will be driving it as a daily and your living in the burbs with traffic. You can get them going pretty good to with some mods.
