5th September 2010, 01:24 PM
#11
I'm in the same boat but the other way around . I just converted my patrol from a ZD30 to TD42T and its done 142k when it stopped . To get my tacho working i had to change the gauge cluster over which had 400k on it . Can anyone recommend me
a auto instrument repair near Melbourne / east of. Or cheaper give me info how to set it
GU Patrol 2001 DX Wagon,
Was ZD30 Now TD42T,
BFG's 305/70R16 Muddies, 2" Lift
5th September 2010 01:24 PM
5th September 2010, 11:48 PM
#12
you could put in a computerised trip meter off the shelf and use it for monitoring k's on motor. Same as rally cars run.
2nd October 2010, 10:44 PM
#13
Might be an idea to make a couple of photo copies of the receipt and have a JP certify it as a true & accurate copy of the orriginal receipt, just in case you miss place the receipt one day.
Cheers,
Rob.
28th April 2012, 09:58 AM
#14
it will still be illegal just log when the new motor went in
Cheers Andrew
28th April 2012, 10:00 AM
#15
12th May 2012, 10:12 PM
#16
get another dash with less kms? would that work
12th May 2012, 11:39 PM
#17
just click the odomiter to 0 on reading a or b and try not to reset it
13th May 2012, 01:28 AM
#18
Nisshead
I think it might have to be reset with the Nissan computer thingy. I thought maybe replacing the instrument cluster but I think the reading might be stored on the ECU
The Odometer reading is stored in the cluster because when my alternator had a melt down and fried my cluster the replacement i got from the wreckers had about 100 thousand more on it than the original one
GU PATROL TB45 | 3" FLEXY LIFT WITH DROP BOX'S | 7" TOUCH SCREEN RUNNING OZIEXPLORER | 33" MT MTZ ON MT SIDEBITER RIMS | XROX TUBE BAR | TIGERZ11 12000lb WINCH
14th May 2012, 04:25 PM
#19
My instrument cluster has been changed. The reading still shows what was shown on the new one. So I would think that it is not stored on the ECU
