29th January 2020, 12:09 PM
ZD30 diesel reserve tank won't shut off when empty.
My diesel reserve tank won't shut off when empty. Car is a 2003 ZD30 Patrol. Reserve tank keeps trying to pump diesel even though empty. Any thoughts. Steve.
29th January 2020 12:09 PM
29th January 2020, 04:35 PM
I am he, fear me
Is your Sub tank fuel qty Gauge accurate?
29th January 2020, 04:44 PM
the evil twin
Hi,yes I check it when I fill it up that it takes 30 litres
29th January 2020, 04:52 PM
I am he, fear me
Steve SA
Hmmm, interesting
The sub tank poota monitors the sub tank qty and should switch off the pump when it thinks the tank is empty
If the gauge is working OK then I would assume the sender and wiring is OK and suspect the "Sub Tank Control Unit".
But before any of that have you added any extra earth straps from the chassis to the body etc?
Patrols are notorious for earthing gremlins esp the Sub Tank System and an "extra" earth strap from the vicinity of the sub tank pump to the body will often get rid of weird faults maybe 75% of the time
mudski (30th January 2020)
30th January 2020, 08:23 AM
the evil twin
Hmmm, interesting
Thanks for that I'll try an earth strap and see if it helps. Steve.
30th January 2020, 10:11 PM
can't you just turn it off manually?
2008 CRD Auto Wagon
Factory snorkel, flashlube catchcan pro, 3" manta exhaust, hpd boost controller, dyno-tuned & egr deleted
