Results 1 to 7 of 7
Thread: Over heating
    Jan 2020
    Over heating
    Hey guys,
    I've got an RD28 1999 model GU and only when the air conditioning is turned on the engine temp starts to go up, but if I turn the aircon of the temp goes back to normal. I've changed the thermo fan for the A/C and still does it. I'm hoping someone might have come across this before because I haven't.
    Cheers Wayne'O'
  2. The Following User Says Thank You to Wayne'O' For This Useful Post:
    MB (28th January 2020)
    472 Post(s)
    G’day Wayne ‘O’ mate!
    Personally not familiar with the legendary 2.8L but I do find on namesake 4.2 kettles in stock form they really appreciate back to basic clean OEM setups.
    A/C fans are a good low speed assistant although the extra load from the A/C pulley engaged does add extra fuel which negates its use. (electrical bypass tips for the fan on only are on here somewhere)
    Only nuffy advice I can offer here is to seriously inspect/clean/replace all the originally working good bits.
    FWIW: After 17years of service we family replaced our OEM 2001 radiator and did drop some top end 10C heat under full duress :-)
  5. #3
    49 Post(s)
    Is the a/c fan spinning the correct way.
    If yes, I'll be checking your cooling system. Process of elimination. Start with the most easiest and cheapest first.
  6. #4
    W.A. (wandering aust)
    Get the Rad professionally serviced, the symptons you describe are the early signs of old age for a GU cooling system
    With the Rad out to get the core rodded the lower portion of the fins can also be cleaned, a quick check of the water pump and thermostat and off you go for another 20 years
  7. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    0-TJ-0 (29th January 2020), MB (28th January 2020)
  8. #5
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    ^^^^^^^^^ What he said! Don't muck about - get a professionalto look at it - it could cost you and engine.
  9. #6
    The master farter
    mudski's Avatar
    461 Post(s)
    My first place to look would be the radiator and the condenser and see if they are full of dirt/ mud etc. Those symptoms tell me theirs either an air flow issue, or coolant flow. Or both. When you put the a/c on, the condensor will heat up, creating extra radiant heat on the radiator. If there is little air flow, or coolant flow, or both, the radiator cannot get rid of this heat quick enough.
  10. #7
    Jan 2020
    Thanks everyone for your input some great ideas and some where to start, thanks again.
