Results 1 to 4 of 4
Thread: GQ Manual Trans ratios
    Just a quick Q about GQ Transmissions
    The manual transmission in the GQ, do all transmissions have the same gear ratios for the TB TD and RD?
    Just did a big trip and really noticed the Gap from 2-3, 3-4 esp on hills. I did swap transmissions when I first got the truck and not sure where it came from.
    Would a TB transmission have different gears ratios as a TD? I thought all the difference was in the Diff ratios.
    Thanks guys
  2. The Following User Says Thank You to The Negz For This Useful Post:
    MB TD42 (16th January 2020)
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    Don't think they are much different...the differential ratios may be...I think the Rb28 is a 4.6...the TD42 is 4.1 and the TB may be the same...
    I use 4.6 diffs with my talker tires so the TD4.2 tows better...
    Try using a higher ratio to beef up the pull?
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
  5. #3
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    There are different boxes used. I think the RB and RD use basically the same box with a few minor differences.
  6. The Following User Says Thank You to mudnut For This Useful Post:
  7. #4
    Thanks. I will try and find the part number on the trans
