15th January 2020, 01:34 PM
Dealer Service? or do it myself?
HI Everyone
I hate paying someone to do something I can do easily and wondering on advice or what others have felt reasonable or done.
I have a 2011 TI 3L Wagon which is due for its 120000k service. The vehicle has been fully serviced by Nissan dealers its entire life up until this point and as its now due I'm completely happy to perform the service myself. I know its a big service changing all oils ect. The only thing I'm wondering is apart from oil/fluid changes and anything else in the service schedule for the 120k is there anything else the Dealer would do?
The reason being its obviously out of warranty so no need to keep schedule with Nissan to honor that, and apart from the shiny stamp they will pop in the book for me instead of my signature is it really necessary?
Will Dealers stamp the book if oils and fluids have been changed and they have checked over the rest? Bit of a half half thing?
Do I just do it myself?
15th January 2020 01:34 PM
15th January 2020, 02:10 PM
120,000km is
engine oil and filter
engine air filter
diesel filter
front and rear diff oils
transfercase oil
manual trans oil
brake fluid flush
coolant flush
re-pack/grease front wheel bearings need new wheel bearing seals to
15th January 2020, 04:34 PM
Hardcore
Couldn’t wait for my extended warranty to run out, now I know the service is done properly as I do it myself.
Easy enough to do.
Jack
15th January 2020, 04:51 PM
Patrol Guru
Just do it yourself. If you can drain your sink you can change diff oil. The only thing in that list that's a bit more technical is the wheel bearings. If you're not confident with those, do the rest yourself and drop it at a reputable mechanic to sort them for you.
The only thing "extra" that they would do is maybe run their eyes over everthing else, check for brake wear and leaks ect.
15th January 2020, 07:04 PM
Adventurist
I've done all of my servicing on my 2016 Y61 myself, since new. Bugger the warranty, I've had too many bad experiences with dealers. If you do it yourself, you know exactly whats done and what fluids have been used. The wheel bearings are pretty easy if you're mechanically inclined, I repacked mine at 40k and check them every service and give them a nip up if neccesary. It also allows you to learn a lot about your vehicle in the process and makes it easier to solve any issues you may have when remote. I'd consider mine far better mechanically maintained than what a dealer would ever do. If it's something that is beyond my abilities or my toolset, I'll take it to a decent mechanic. One thing on my wish list is a vehicle hoist though, getting a bit old to be crawling around under it!
2016 GU Legend Edition: 3505Kg GVM Upgrade and Stuff!
15th January 2020, 08:56 PM
Do it your self mate. At least the oils and filters on everything. You'll save $, and get to learn your car better and know whats done and what stuff was used on it.
16th January 2020, 07:56 AM
Cheers everyone for the input. Much appreciated.
Looks like the consensus is do it yourself if you can.. so that's exactly what I'm going to do. I'll start rounding up some oils and go from there. As for other things to check like fluid leaks I feel I'm pretty much on top of that as part of my normal maintenance regime which is the Six P's.
Thanks all
16th January 2020, 09:30 AM
#8
Travelling Podologist
gavcan01
If you haven't changed all the oils in one hit previously the cost of the oils is a real eye opener, or at least it was for me! Not a cheap exercise. Getting the oils into the diffs, gearbox & transfer case is much easier if you use the easier flowing synthetics. Make sure you use the specified GL rating. In mine (TD42i) it is GL4 is specified. First time I changed the gearbox oil I thought a later GL5 oil would be ok if not better. Wrong. It isn't. When I finally woke up & replaced it with GL4 oil it made a significant improvement to gear changing when the motor was cold.
16th January 2020, 10:04 AM
#9
Expert Dingbat
Cheaper for me to get the local 4wd mechanic to do my major service...buying all the parts alone is the same price...lol...let alone having the time to go over the whole car...
Minor services...well I check the rig before every trip so thing get done when they are needed...not much goes wrong with a mechanical diesel if it not thrashed...good ol tractor.
Quad-Drive 4WD Club...Western Australia
We're all here coz we ain't all there...
