6th January 2020, 02:22 PM
Travelling Podologist
We spent a couple of months in the Channel country in 2017.
Check out my blog, go to Posts/Previous Posts' & look at approx August & September entries.
This link is to a map of the trip up there & back from Victoria. You can zoom in for a closer look. http://cuppa500.com/Blog/map-queensl...annel-country/
2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3 ” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare)
The Following 2 Users Say Thank You to Cuppa For This Useful Post:
Brissieboy (6th January 2020), mudnut (6th January 2020)
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
Forum Rules
