21st September 2010, 12:20 PM
Tail light assembly removel
I'm stuck, I can't seem to find the instructions on how to remove the tail light assembly, I've got the two main screws out and I know there is more but I can't remember where and I can't find it in the on line Manuel .can some one help me.
for a 2000 GU wagon.
21st September 2010 12:20 PM
27th September 2010, 01:04 PM
The Following 3 Users Say Thank You to mrjimmypit For This Useful Post:
Col.T (30th November 2010), MudRunnerTD (4th July 2011), Stevet (9th October 2010)
1st July 2011, 12:39 PM
Stevet
led tail lights for trucks assembly, I've got the two main screws out and I know there is more but I can't remember where and I can't find it in the on line Manuel .can some one help me.
having the same problem so i try the link that "mrjimmypit" recommended. well it really help me a lot. thanks for the thread!
4th July 2011, 03:58 PM
Hardcore
I thought id add this ,as those instructions don't mention it, but when installing the drivers side tail lamp, take care to ensure you do not trap the rear washer/squirter water feed pipe.
This rubber hose/pipe runs very near to the tail lamp bracket, it is held just enough out of the way by a factory tie, but sometimes when playing around inside (with wires etc) the water hose can fall down and get slightly trapped or squeezed when you tighten up the tail light retaining bolts.
This could cause a leak, or stop water coming out the rear washer all together (as happend to me)
The Following User Says Thank You to 04OFF For This Useful Post:
ghostrider_oz (15th July 2011)
19th September 2012, 07:52 AM
Zombie thread will eat your brains.............
Resurrecting this old chestnut as I can't see how to get the light covers off for the lights either side of the barn doors (not the one in the rear bar). They're sealed from the outside and I can't get my hand in through the back.
Can anyone suggest how to get to the bulbs before I rip or break something off....
Rob
Love is a TD42T
19th September 2012, 07:58 AM
On the GU its in behind the Jack cover on one side and the pull out insert on the other, 2 x 10mm bolts either side ,might need to thump with your palm carefully to dislodge
The Following 2 Users Say Thank You to threedogs For This Useful Post:
ova50 (21st October 2012), snewin (19th September 2012)
19th September 2012, 08:10 AM
Thanks very much 3D. I was going to undo the bolts but didn't want something bad to happen. You're a champ.
Love is a TD42T
14th November 2012, 12:30 PM
#8
Digging up an old thread,
The better half informs me the other day whilst backing into the garage, that the drivers side reverse and brake lights are out. I'm thinking probably the clip has fallen out, no biggie. Today I've taken her out and no word of a lie found that the entire tail light assembly didn't have any globes, wiring or anything hooked up to it.
I was absolutely flabbergasted. How could something like that be passing rego for 4 years! Stupidly it was the one thing I didn't check before I handed over cash for the bloody thing. Thankfully It's still under the statutory warranty.
03 ST 4.8L Auto Juice Guzzler
14th November 2012, 12:48 PM
#9
Hi James,
Check old posts and you will find rear lights are dummies as they do not comply with the ADRs (spare wheel blocks the visual of RH light, that is why they are in the lower bar. I have replaced mine with ones I purchased from EBay ($120.00) fully wired with globes. The passenger side plugs straight into loom drivers side you have to source Earth, and Reverse. Do a search there is a heap of info on previous threads.
Bazz
The Following User Says Thank You to Bazhemps For This Useful Post:
James_R (14th November 2012)
14th November 2012, 01:31 PM
#10
Thanks Bazz, appreciate it mate. Still flabbergasted but I appreciate the quick reply.
