24th December 2019, 02:27 PM
Never knew that I needed an oil cooler
I finialy got around to puting my Gu steering box in my Gq and all seemed fine until it gets hot and the noises it makes is like there is air still in the system and it starts pushing fluid out of the cap at full lock, but when it is cold all is good so I compared the systems together and low and behold the Gu has 2 oil coolers on it and nothing has ever been said about adding PS coolers on along with the Gu box
The Following User Says Thank You to First Pooy For This Useful Post:
24th December 2019 02:27 PM
24th December 2019, 09:18 PM
24th December 2019, 09:49 PM
Reckon you could quite easily when time permits cut into the GQ loop mate for cooling if found needed after bleeding.
A professional cut and flaring of the incoming and outgoing lines would allow you to modify although please do be careful as I am certainly no pressure or mechanical expert :-(
24th December 2019, 09:52 PM
A stock GU TD42T system for continuation out front reference mate!
