Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: TD42 upgraded fan and hub assembly
Hybrid View
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Hi all, I've done a few decent hill climbs and drives in high 40's (49deg on Friday) and notice the water temps rise quite quickly towards 100deg since the new pump and turbo. Haven't had it overheat yet but I'd like a bit more wiggle room for when I want to tow.
    Amongst other things I want to put a new fan and hub on. I've seen a few people recommending the UFI upgraded fan and hub assembly but also see "quick azz" advertising on eBay making claims thiers is the bee's knees.
    Anyone got any personal knowledge of the differences between them?
    https://patrolapart.com.au/product/u...l-gu-td42-tb45
    https://rover.ebay.com/rover/0/0/0?m...2F202471966353
    I'm not sure what @MudRunnerTD has but he's upgraded his fan hub assembly to good success. He can probably point you in the right direction?
  3. The Following User Says Thank You to rusty_nail For This Useful Post:
    0-TJ-0 (23rd December 2019)
    175 Post(s)
    I think he is running the G35 fan like @mudski and my self. A cheaper common alternative with good results.
    https://patrolapart.com.au/product/g...patrol-gu-td42
    After I fitted this fan I found my temps recover quicker after a bit of load. You can hear this fans air whooshing compared to the factory TD fan. Also adding some oil to the hub will make it work harder (spin more of the time), will help a bit. @mudski is the man here, hes experimented a lot with this and found a sweet spot, helped me heaps too.
    There is also a certain Pajero model fan, that can be adaptored to suit a TD which is meant to be good. I believe @Winnie mentioned this recently.
    Jan 2017
    South Australia
    11 Post(s)
    Oh yeah. That must be the fan the ebay mob are using. They mention its a Mitsubishi fan
    Yeah the UFI one uses the same Mitsubishi fan and hub, the only difference is the adaptor they make.
    I can't comment on the difference between them as I haven't seen either.
  7. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    0-TJ-0 (23rd December 2019), Hodge (23rd December 2019)
    Jan 2017
    South Australia
    11 Post(s)
    Ended up trying the "Quickazz" mob. Was a good buying experience, fast shipping and a scootch cheaper than others with the full fan and hub assy. I've had zero issues with patrolapart in the past.. but $30 saved will pay for the scotch to help me fit it.
    Did manage to get it fitted today but I haven't been for a drive yet. Will report back, probably after Australia day weekend on the results.
  9. #7
    Patrol Guru matfew's Avatar
    Nov 2012
    Got mine in last week. Sitting in tassie loaded to the hilt and remote have never been as low or stable ever before.
    Could not recommend it more! I thought mine was actually running a tad cool this morning haha. Never EVER have I thought that before lol
    Sent from my Pixel 3 using Tapatalk
  10. The Following 3 Users Say Thank You to matfew For This Useful Post:
    0-TJ-0 (13th January 2020), MB (31st January 2020), PeeBee (13th January 2020)
  11. #8
    Jan 2017
    South Australia
    11 Post(s)
    That's what I was hoping for! I haven't yet over heated but I have seen the gauge headed that way.. Just wanted a bit more wiggle room haha. Your post gives me hope!
  12. #9
    Jan 2017
    South Australia
    11 Post(s)
    Just took it for a short drive.. I tell ya, when the fan gets going it starts to worry me that it might suck a small child in through the grill if they get too close. Total different sound now.
  13. The Following 4 Users Say Thank You to 0-TJ-0 For This Useful Post:
    dpetersen (28th January 2020), Hodge (15th January 2020), matfew (21st January 2020), MB (29th January 2020)
  14. #10
    472 Post(s)
    No doubt wrong here again :-(
    Here’s hoping there is no correlation between mechanical donk bigger cfm fans and stock water pump bearings/seals to OEM suit?
