19th December 2019, 08:17 PM
93 GQ injector pump inlet banjo / filter
Hi
After reading through a few post I decided to take a look at my injector pump filter.
TD42.
It has a large head banjo with a 10mm hex bleed type bolt in the top of it and a long plastic looking filter inside the bolt.
What really surprized me was that the fuel hole through the side of the bolt was only about 5-10 thou diameter.
The filter was blocked badly.
Is this small fuel hole normal??
19th December 2019 08:17 PM
19th December 2019, 08:35 PM
Hole size is normal and throw out the gauze filter.
Convert (19th December 2019)
19th December 2019, 08:38 PM
I see that the filter is retained in the bolt with 3 crimps at the thread end.
Should I drill them out to get the filter out?
