Results 1 to 10 of 10
Thread: Changing GU rear wheel bearings
    So. I've own the Patrol for some seven years. The ODO is nudging 480k. I've done over half of that since owning it. I've never touched the rear wheel bearings. I don't even really know how long it should take. I'm heading off for two weeks on the 5th of Jan and now I'm a bit paranoid that I should be doing them before I go. Cutting it fine though I think.
    What tools are needed? I have a press but I think, the bearings on the rear need to be removed differently. I think.
    Any tips?
    Jun 2019
    Central Coast, NSW
    If they aren’t causing problems then just go away for two weeks.
    Quote Originally Posted by pspeirs View Post
    Yeah Im thinking that but paranoia starts to sink in...
    175 Post(s)
    Marky Mark.
    I have NFI about rear bearings.
    But when I had my front bearings replaced recently , I asked when should I look at the rear.
    Answer was that unless they give you grief , make noise or you're constantly carrying a lot of rear weight ... Then don't touch them. They will outlast the rest of the vehicle. Also apparently they are an absolute prick to press out.
    Marky Mark.
    Yeah I know but at nearly half a million k's on them, I really think they should be replaced. Just not now maybe. Lol.
    Hodge (17th December 2019)
    175 Post(s)
    And as always , If you do pull the trigger and need a hand yell out.
  9. The Following User Says Thank You to Hodge For This Useful Post:
    mudski (18th December 2019)
  10. #7
    Thanks. Getting the bearings off if where I will come undone. I dont have the right tool, or even know what the right tool is to do it.
  11. #8
    May 2016
    lower west victoria
    30 Post(s)
    Look at it differently.
    Are you going somewhere where if the bearings fail, you'll really be in trouble, waiting days for someone to come across you, having to leave your vehicle, possibly abandoning it because you're so remote. Or will you be somewhere where you can get towed to a garage within the same day and get them done?
    If you're going to be remote do them.
    If you're staying within a rescue-able range of somewhere, leave them.
    That's how I'd look at it.
  12. The Following User Says Thank You to 10G For This Useful Post:
    Cuppa (18th December 2019)
  13. #9
    Ballarat, Vic
    174 Post(s)
    I was a tad paranoid about heading off alone into remote areas without knowing my rear wheel bearings were good. This was at 200k (12 years old). Bit the bullet & got them done, even though they had given me no grief, nor made any noise. We do carry a lot of rear weight though, & I suspect the previous owners (Telstra) did too.
    One side was showing a bit of blueing, had been getting hot because the grease in there had dried up. The other side had a minor oil leak past the seal.
    If yours are not getting hot or making noise I'd reckon you'll probably be OK & get them done after you get back. I would think that a catastrophic failure (as in cannot proceed) occurring without warning would be very unlikely, & unless you are likely to be many hours/days from somewhere the RAC would recover you from (assuming you have RAC recovery) you would get by with some inconvenience at worst. You have to balance this against the inconvenience/difficulty of finding a mechanic at this time of the year!
    The rear bearing are pretty substantial items, far bigger than front wheel bearings.
  14. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    Hodge (18th December 2019), mudski (18th December 2019)
  15. #10
    Legendary happygu's Avatar
    If it makes you feel better, the rear wheel bearings won't normally spontaneously fail.
    They will grind / make a noise to let you know - which gives you a little bit of time up your sleeve to get them fixed.
    Head away, and plan to do them at a later date that suits you better....
  16. The Following 3 Users Say Thank You to happygu For This Useful Post:
    Cuppa (18th December 2019), Hodge (18th December 2019), mudski (18th December 2019)
