14th December 2019, 09:09 PM
Air Compressor Advice
Hello All,
1988 GQ Patrol Need a descent compressor for inflating 32" tyres
24V truck: So my selection of Compressors is limited. I was looking for an underhood mount with front and rear fittings.
So I have been looking around for a 24V compressor for my dedicated tourer. And my next trip has me beach camping my way up to Cairns so I will be on and off the sand heaps and will be doing lots of inflating.
What are your opinions on my options. The more expensive units are based on the shit talk of my TJM loving mate, I assume heaps of people run the ARB Single all day every day no problems.
ARB High Output Single $345. I had settled on this one but talking to a buddy who has run the 12V version and now on the new TJM 100% duty cycle (vs 50% for ARB), says its night and day and not to get it.
Air On Board compressor with 9L Tank $358: Much more affordable but now need to mount a tank. https://www.aironboard.com.au/store/...ersal-kit.html
Boss Air System $669. Looks to be a better compressor than the air onboard and still has a tank https://bossairsuspension.com.au/onb...ack-air-pro-3/
ARB Twin High Output $890 With Air Tank and lots of extras (Christmas Deal) or $650 For just the twin. A big step up in price but it does have a small 4L tank Tyre repair kit, Digital Inflator etc. I also was looking to mount under the hood and run a fitting to the rear or front and think this unit will be too big. Also the price
Endless Air $800: For 900 bucks I can get the endless air belt drive system. just not sure I can get in shipped and installed before I leave on the 28th.
14th December 2019 09:09 PM
14th December 2019, 09:42 PM
Travelling Podologist
If I could have fitted it, an Endless Air unit would have been my choice, but on the later td42i gu it requires a bit of chassis butchering which i wasn't happy about. So I got a Boss PX7 & have been happy with it. I have a 9 litre tank which in hindsight isn't really needed for inflating tyres, & is too small to be useful for most air tools. Being able to use a blow gun whilst travelling has been useful to clean/dust stuff when doing any mechanical work on many occasions however. Based upon my experience I'd say that a smaller tank would be pretty much good for nothing. 100% duty cycle is very worthwhile however, especially in the warmer parts of the country.
15th December 2019, 09:12 AM
The 747
I can't compare to the TJM or any other units, but I have the single ARB compressor and although it's reliable and gets the job done, I really regret not getting the twin.
The Following 2 Users Say Thank You to Winnie For This Useful Post:
Hodge (15th December 2019), mudnut (15th December 2019)
15th December 2019, 12:06 PM
Moderator
I have a single ARB too. If i had the choice again the the Twin would get my coin too.
Check out my Toy -->
Rogue Dung Beetle
15th December 2019, 12:13 PM
This is something that I will do and it looks like the twin is the way to go.
15th December 2019, 10:25 PM
I am putting in a call to Boss tomorrow to ask about the PX07 as a stand-alone compressor as it seems to flow the same as the ARB Single but is 100% duty. but for 500 its pretty close to the twin and will come down to size
16th December 2019, 01:30 PM
I run the ARB twin and its good. Not sure how good it is against other brands though. My only gripe is the small air tank that it has get a lot of moisture in it. But being mounted under the passenger seat, I have yet found an inline filter that I can fit under there.
Running the compressor, relay and switch of one battery is all you do in a 24v system.
16th December 2019, 01:53 PM
#8
The Negz
The PX-07 is selling for $349/free shipping on ebay right now. Its a huge difference in price for something that will be used infrequently I would think. I looked at both and the performance is so similar so I went the PX-07 - yet to use it, and have no experience with the ARB twin, but if its like the other two ARB units I have it will be a beauty for sure - simply not convinced on the $ side of the equation. I did however have my ARB difflock compressor fail due to the piston seizing in the bore, however it was covered under warranty. I also liked the readily avail. re-build kit for the PX-07, however you could also ask why such a kit is readily avail - maybe they don't last under constant duty load?
16th December 2019, 07:25 PM
#9
Thanks all for the advice, Boss had no PZ07 in stock and all the eBay listing where a bit jacked up. Also, boss highly suggests a receiver tank and with 2 weeks before I leave trying to find and fit it was going to be a pain.
I ended up going with the Sherpa Big Air unit, it can be mounted our used as portable. it's cheaper than the Boss air with a tank etc. The flow specs are impressive with 5.2cfm at 80 PSI that is leaps and bounds compared to others and its 100% duty.
https://www.sherpa4x4.com.au/collect...air-compressor
The 12V version is 100 amp draw so makes sense where it gets the grunt from.
Thank you all for the advice this forum never lets me down.
16th December 2019, 08:06 PM
#10
