Results 1 to 9 of 9
Thread: Upper front door hinge
    Aug 2019
    Bathurst NSW
    Hi all
    I have the usual squeaky and sagged GQ upper front door hinge that I need to replace.
    Just wondering if I can I fit a spanner or socket in and remove it with the guard still in place?
    462 Post(s)
    Bit fiddly but yeah you can. Well on the GU you can...
    Yes, I did it on two of mine.
    As Mudski said, it is a bit fiddly but IIRC an appropriate extension with a uni knuckle adapter gets the job done... ratchet ringy with the adjustable angle handle helps as well
    Jan 2018
    Pt Augusta SA
    I recently did my upper hinge without removing the guard. Very fiddly but doable.
    Pete
    Aug 2019
    Bathurst NSW
    Thanks guys, I'll give it a shot!
    472 Post(s)
    FWIW: I remember a member (‘GQ42TD’ -I think) kindly posted up a while ago a neat trick of using a medium to large size step ladder straddling his GQ open door with some little ratchet straps to assist weight and as a second set of hands on his lonesome
    462 Post(s)
    Quote Originally Posted by MickGQ View Post
    Thanks guys, I'll give it a CRACK!
    That's the spirit!
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Nah had to unbolt the guard to get at the hinge bolts but yes used a ladder to hold the door roughly in place , have since seen someone use packing washers on the bottom hinge which I must try on the passenger side .
  10. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    MB (13th December 2019), Palmo-GQ (19th November 2020)
  11. #9
    Jun 2018
    24 Post(s)
    I've had some success with packing washers on the bottom hinge. Easy to put in too.
  12. The Following 2 Users Say Thank You to Cremulator For This Useful Post:
    MB (15th December 2019), Palmo-GQ (19th November 2020)
