Results 1 to 8 of 8
Thread: Copper brass radiators
    Sep 2017
    Hi guys
    I've got an 88 GQ TD42t and the stock copper brass radiator has a broken overflow nipple. I'm tossing up between getting it repaired or just buying a new radiator since I don't know the history of my radiator other than the fact it was rebuilt about 5 years ago.
    Does anyone have experience with copper brass radiators from Auto Parts Supply online? It seems like a decent OEM style radiator for fairly cheap.
    https://www.autopartssupply.com.au/n...copper-suit-rd
    194 Post(s)
    @mudski, @MB I believe have been thru this - OEM or validate copy is the go I believe?
    462 Post(s)
    Yeah I had a custom copper brass rad, was about $700, can't remember the mob who made it now...Then went back to OEM style Koyorad branded ally rad. Zero different in cooling I found.
    As for the OP. Just by looking at their shop, they might be selling chinese imports. The quality of materials used might be questionable. EG. Is the copper real copper or a blend of lead and whatever else is cheap at the time.
    Radicool I think was the mob who did my copper brass rad. I think...
    Expert Arfa Brayne's Avatar
    Jul 2016
    re-solder the overflow nipple. Just need a wire brush, flux, solder and gas torch. Done in under 15 minutes. DIY cost = S.F.A.
    If you were in the 'Gong I'd say bring it over with a few beers one afternoon = easy as.
    If the radiator is only 5 years old it's got another 15 years in it.
    "Can't" is a dirty 4 letter word.
    Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
    Sip on the "t", and consider what you've got left to work with
    462 Post(s)
    Quote Originally Posted by Arfa Brayne View Post
    Yeah I reckon any decent radiator mob could give it an acid bath, solder up the broken joint for way less than a new radiator.
    Beginner RickGQ's Avatar
    Jul 2019
    Sydney (West)
    If the existing radiator is doing its job, that is, keeping g your engine cool enough, then just save the money and get it repaired.
    1991 GQ Wagon
    TD42
    Safari Turbo
    And a few add-ons.
    ...28 Patrol years and counting...
    Yep. A mechanic recommended the same thing, today. If it is in good nick, get it repaired. I got mine done four years ago. It needs to be done again, but it is still way cheaper than a new one.
    Sep 2017
    Thanks guys, thats the info I was after. I'll get it repaired instead of replacing it with something cheap.
    '88 GQ Safari SWB, TD42ti, 2" lift, 33" A/T, PTO winch
