Results 1 to 3 of 3
Thread: 93 GQ injector pump inlet banjo / filter
    Beginner Convert's Avatar
    Dec 2019
    Hi
    After reading through a few post I decided to take a look at my injector pump filter.
    TD42.
    It has a large head banjo with a 10mm hex bleed type bolt in the top of it and a long plastic looking filter inside the bolt.
    What really surprized me was that the fuel hole through the side of the bolt was only about 5-10 thou diameter.
    The filter was blocked badly.
    Is this small fuel hole normal??
    461 Post(s)
    Hole size is normal and throw out the gauze filter.
    Convert (19th December 2019)
    Dec 2019
    I see that the filter is retained in the bolt with 3 crimps at the thread end.
    Should I drill them out to get the filter out?
