Results 1 to 10 of 13
Thread: Jumper Leads???
    May 2016
    lower west victoria
    30 Post(s)
    Jumper Leads???
    Went to eBay to get some jumper leads, didn't think much about it.
    200A, 700A, 1200A, 3000A.
    What capacity leads do I need for the ZD30???
    Thanks guys.
    Patrol Guru matfew's Avatar
    Nov 2012
    They are always shit quality wire so buy the biggest you can afford never hurts to have bigger in this case.
    But to give you an idea I've jumped a car with tiny wire before. It just gets hot. Too small or if battery is too dead and it corks smoke the wire on smaller ones
    Sent from my Pixel 3 using Tapatalk
  4. The Following User Says Thank You to matfew For This Useful Post:
    04OFF (7th December 2019)
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    From my humble opinion and my own experience, the larger the cable core, the better, especially if you want to start a Diesel
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    I have these
    https://automotivesuperstore.com.au/projecta-nb750-60sp
    May 2016
    lower west victoria
    30 Post(s)
    I have these
    Holy crap YB, you must do a lot of jump starting?????
  8. The Following User Says Thank You to 10G For This Useful Post:
    Yeti's Beast (7th December 2019)
  9. #6
    Aug 2016
    Jimboomba
    4 Post(s)
    Jumper Leads???
    No
    I acquired them through work
  10. #7
    22 Post(s)
    Lol...those rating are a joke.
    Just buy the largest cross sectional area you can afford. Or go and buy your own cable from a electrical supplier, nice big clamps from an industral/ welding supplier and make your own
    Edit..... for shits and giggles.
    For a (true-ish)3000A, 6m long jumper lead set, you would need parallel 630mm2 leads (2 per lead). 630mm2 is 6.3Kg/M, x 24m = 151.2Kg of cable.
    96 GQ coil/Cab
    08 G6eT
  11. #8
    194 Post(s)
    70mm2 welding leads with good clips will start anything in any weather. I have 8m leads and they sit nicely in a canvas bag in the back. Check out a welding supplier or surf around for a good price. Don't lend them to anyone because they wont come back - know this from experience!
  13. #9
    Aug 2016
    Jimboomba
    4 Post(s)
    Learnt the same lesson
  14. #10
    Aug 2016
    Jimboomba
    4 Post(s)
    Ok looks like I led you up the garden path
    They looked similar. Oops
    My leads are Matson brand 50mm sq
    Still heavy enough to start most things
  15. The Following User Says Thank You to Yeti's Beast For This Useful Post:
    PeeBee (7th December 2019)
