Results 1 to 10 of 13
Thread: Diagnostic link connector / consult port, location 4 a 1992 GQ TI?????
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Hi all,
    Does anyone know where i can find the Diagnostic link connector in a 1992 EFI GQ TI???
    Not sure if its called Diagnostic link connector or Consult port
    Am looking at buying ECU Diagnostic software.
    If anyone has bought this type of stuff could u please tell me the software you are using and your opinion on the software.
    Cheers in advance
    Todd
    Banned
    Todd the GQ workshop manual (the factory one found here) has a section on manual diagnostics & lists the how too's & what each code represents if thats any help.
    Paul
    581 Post(s)
    Quote Originally Posted by toddrhind View Post
    Hi all,
    Cheers in advance
    Todd
    That's something that Ive always been interested in Todd. I can't give you any advice but if you do go down that path please let us know any info.
    Aug 2010
    17 Post(s)
    thanx Paul for ur post, u wouldn't happen to know what page number in the workshop manual i would find the info??? Have had a quick look, find it very hard to read the workshop manual i downloaded
    Aug 2010
    17 Post(s)
    Hi Andy,
    I will be going down that path when i suss it all out. My dad also owns a GQ patrol and he has just purchased something called "OBD2 All-In-One Scan Tool w/ USB"
    http://www.obd2allinone.com/sc/details.asp?item=obd2usb
    Not sure if i will purchase the same as him, but considering he is more mechanically minded than me i prolly will.
    Todd
    Banned
    When I get time to look I'll find it....
    Which copy did you download BTW?..... there is 2 to download one is the factory Nissan GQ/y60 service manual & the other is a scanned copy of a Gregory's.
    Aug 2010
    17 Post(s)
    Quote Originally Posted by patch697 View Post
    Thanx Paul, no rush. I'm pretty sure it was the factory Nissan GQ/y60 service manual that i download, which looks very scanned 2 me, I find it hard 2 read anyway, it has 1038 pages.
    Sep 2010
    Might be the 14 pin RHS tucked in above the fuse box (Diagnostic connector). you can read the ECU 2-Digit fault codes by putting ECU into diagnostic mode. Think this must be in nissan manual.
    Procedure: Turn key to ignition position and engine not running. Bridge for at least 3 seconds the 2 wires adjacent to each other, placed in there own group, at one side of the 14 pin connector. On mine, this is the white/red and yellow/black . The" check engine" lamp will pulse out the 2 DIGIT fault codes. 1st Digit-slow flashes, 2nd Digit-fast flashes.
    The code(s) are repeated until you exit diagnostic mode by bridging the 2wires again for 3 seconds, when finished reading codes.
    Codes: a) 11- crank angle sensor, b) 12- air flow meter, c) 13 - temperature sensor, d) 21 - ignition , d) 43 - throttle position sensor, e) 55 - NO FAULT DETECTED. Note. Any reported fault can occur due to faulty wiring in particular high resistance in the connectors. This has been the main problem with my GQ. Suggest all connectors are cleaned with "contact cleaner" before investing in sensor replacement.
  10. The Following 4 Users Say Thank You to ensayboy For This Useful Post:
    Finly Owner (12th September 2010), NissanGQ4.2 (12th September 2010), pa'stroltribe (12th January 2017), skidy04 (12th May 2012)
  11. #9
    Banned
    I did find this in my travels Todd if its of any help.
    http://www.ecutalk.com/ecutalk.aspx
    Paul
  12. The Following User Says Thank You to patch697 For This Useful Post:
  13. #10
    Aug 2010
    17 Post(s)
    Thanx Paul,
    I have viewed this website before and might be buying the cable that they have, just waiting on my dads OBD2 All-In-One Scan Tool w/ USB to arrive so i can have a look at that one to see what its like.
    Will keep u posted to what i end up doing.
    Thanx for the website addy anyway
    Todd
