Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: MaxTrax Mounting Straps???
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    Wondering if anyone has used the Maxtrax mounting straps that let you strapp maxtrax onto your rear mounted spare wheel???
    https://www.maxtrax.com.au/product/m...wheel-harness/
    Are they any good, would you buy them again???
    Legendary
    193 Post(s)
    With that amount of money hanging off 4 elastic clips, I think I would rather them on the roof and strapped down. I have 4 of them and would not mount on the spare wheel, simply as I would be afraid they drop off and I would not know. But saying that it is their mounting system - would be interesting to find out what they would say if you made a claim for lost maxtrax due to failure of their strap.
    330 Post(s)
    I use Electrical Zip ties and tie it to the roof rack. Secure and a pair of side cutters have them off the roof in seconds. Not really an issue, normally you have plenty of time to sort out your recovery set up so quick access is not really an issue. Quick access to a Shovel though is a No Brainer yet people use those roof rack mounts that require you to get a shifter out to unbolt the shovel. Makes no sense to be at all. Plenty of guys will struggle way rather than grabbing a shovel because it is bolted up. I can get my shovel working in 10 seconds.
  5. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Hodge (25th November 2019)
  6. #4
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    Yep, zip ties are a good idea. Decided against the spare wheel mount as it'd be too much for the rear door hinges I reckon.
    May look at making a mezanine level for my roof rack, looked into this in the past. High enough to put 2 maxtrax into it and more stuff on top.
    I made some maxtrax holders, simply a bit of pipe welded to some flat x 2. The flat bolts to the rack and one of the bits of pipe has a hole in it that a padlock goes through.
  7. #5
    330 Post(s)
    If there is enough room under the rack for 1 max trax thickness then just tie them inverted under the rack with zip ties and forget about them. One down each side so you can still reach to cut the zip ties under them. They are not going anywhere.
  8. #6
    472 Post(s)
    Met a great old bush bloke mentor last Christmas, heaps of shell grit/sand/desert experience too found after picking his brain.
    Turned out that on our little convoy way to the 3hr beach journey up to the mouth of the Mighty Murray River his basic canvas sheet wrap package on his roof rack was actually for UV ‘Trax’ protection.
  9. #7
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    I would have reckoned that all these 'boards would be UV resistant/tolerant. It can't hurt though to cover 'em up I guess.
    I contacted a bloke on FB about these straps. He used them on his. ahem, Cruiser. Said they worked ok but were a reeal PITA.
  10. #8
    The master farter
    mudski's Avatar
    461 Post(s)
    I just use a couple of occy straps on the roof rack. So simple...
  11. #9
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    I think you might find the boys in blue or your state transport authority might not like any load 'secured' with occy straps. They can issue 'insecure load' infringement notices for this.
    Plenty do it, but that does not make it legal.
  12. #10
    The master farter
    mudski's Avatar
    461 Post(s)
    Quote Originally Posted by Brissieboy View Post
    How are they not secured? They are held down tight, the straps are not worn or freyed in any way. Furry muff if they were in not good shape...If not occy's, a could of small ratchet tie downs then. Probably just as easy as occy's.
