3rd November 2019, 08:55 PM
Help /advice on gu lacking power
Wondering if anyone can help I have recently bought a 2005 GU coil 4.2tdi (manual) only 220 on the clock, she really lacks power in lower gears .. sluggish ! love everything about her so hoped someone may have experienced the same . My partner has 79 series landcruiser which flies past so you can imagine the comments I get any advice appreciated before I go to a mechanic so at least I can have some idea being a girl 👧 lol
The Following User Says Thank You to Samantha Kidd For This Useful Post:
juzzs8 (4th January 2021)
3rd November 2019 08:55 PM
3rd November 2019, 09:05 PM
Sons absolutely flys down low and no expert but I'd find out what the boost pressure at the turbo is apart from the usual airfilter etc .
3rd November 2019, 11:06 PM
Moderator
Samantha Kidd
any advice appreciated before I go to a mechanic so at least I can have some idea being a girl �� lol
Likely it has never been touched out of the factory. They are a bit of a slug. But... I mean BUT. They respond very well to a decent dyno tune for a start.
Fit an Exhaust temp gauge and a boost co trolled and have it tuned for the first win.
Remember your BF has a 4.5 V8 and you have a 4.2 straight 6. His will be stronger but you have way way more potential than he does.
Start with a decent tune. Then come back and say g'day and we can help you spend some cash to make him squirm... lol
He has a V8.... But it's a little V8. V8 Toyota driver's are wankers who think the end of the sentence is V8. Td42s are a Beast motor when the right mods are done.
Welcome here.
Check out my Toy -->
Rogue Dung Beetle
The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
GQtdauto (4th November 2019), Hodge (4th November 2019), juzzs8 (4th January 2021)
4th November 2019, 08:25 AM
Yup as Mudrunner said, a nice tune, and from there on, there are things that can make them absolutely sing. Exhaust, larger intake and then from there with some more $, but not necesary a better turbo and pump will blow the tits off any 1VD-FTV.
4th November 2019, 10:53 AM
'Tis true! Mine is fairly mild, won't beat the 'crab off the mark but annoys the shite out of 'em when I'm trying to park on their tray at 130k
4th November 2019, 11:03 AM
Travelling Podologist
Check out my post from 3 years ago. A 3" exhaust & dyno transformed my '06 TD42i from a piece of wet lettuce into the car it should have been off the factory floor. It is still no 'speed machine', but I love it.
http://www.nissanpatrol.com.au/forum...+exhaust+cuppa Post #8
2nd December 2019, 10:04 PM
Sounds like a stock gu 4.2 to me...when I originally bought mine I came from a bt50 with a lot more power and a lot more earlier power in the rev range...so the patrol disappointed me the main thing I hated was how much turbo lag the patrol had 2000rpm was jsut to late for the power to come on...did a lot of reasearch and ended up fitting a p4x4 16g turbo Which transformed the car power was a lot earlier around the 1700-1800 range and with a tune they come onto power even earlier...
3rd December 2019, 07:33 AM
I’ve got an ‘05 4.2td wagon had since new. Never had anything done other than a 2” lift.
Around the 210000km mark I found it under power towing my heavy camper trailer.
Took it to a reputable diesel bloke in Narellan and had a good talk.
Fitted 3” dump pipe, 3” Redback exhaust, new injectors and dyno tune.
Result = a powerful new truck.
This was my experience, but you may be different.
3rd May 2020, 02:45 AM
shakey55
How much did that set you back in $?
What sort of results did you get on the Dyno?
3rd May 2020, 06:12 AM
Seafarer
It’s on long ago to remember the exact cost but I do know that it was reasonable for what was done. I’ll look for receipt, but don’t like my chances.
This was the dyno print out and I have been very happy with the vehicle’s performance since having this little bit of work done
