Results 1 to 4 of 4
Thread: No ac and no air through vents
    Oct 2018
    Hey all,
    Just picked up a gu patrol ti model tb45 with auto climate control, im finding small little things to fix but this ones the annoying one.
    Basically i have no cold air at all which i probably have no ac gas but i alsp have no air coming through the vents they only come through the window vents and as well as the rear vents when i turn them on
    Anywhere where i should look first?
    Cheers fellas
    The master farter
    mudski's Avatar
    462 Post(s)
    Make sure that the cables from the control to the heater box are connected and working properly.
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    If the fan is working, try checking that the filter isn't blocked. https://www.youtube.com/watch?v=Fh7bbjuzXmo It will be reverse for right hand drive.
    Oct 2018
    Thanks for the replies solved the no ac problem there's no belt attached for some reason easy fix hopefully.
    As for the vents i suspect its either the control unit faulty or wiring because i cycled through all the modes all the air is coming from the window vents regardless i select the normal vents and foot vents. There's no cabin filter and i unplugged and reconnected the control box
